clinton Occasional Visitor
Joined: 06/03/2003 09:47:09 Posts: 9 Location: United Kingdom
Posted: Mon Jan 19, 2004 12:46 pm Post subject: TomTom Navigator 1 and O2 XDA2? |
HI,
I am about to purchase an O2 XDA2, but first want to make sure it supports TomTom Navigator 1 ?
Thanks! |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Mon Jan 19, 2004 3:32 pm Post subject: |
The XDA II supports TomTom 1 as a program. Your problem will more be in the kind of GPS receiver you are planning to use. TomTom 1 was conceived before the broad acceptance of BlueTooth receivers., and the BT COM port may not be visible in the TomTom GPS applet. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jan 19, 2004 4:58 pm Post subject: ? |
Thanks for the help!
I was using my bluetooth globalsat GPS with TomTom 1 on my iPaq 3970, but now want to upgrade to an XDA2 but with using the same software and GPS.
Is it then okay?
Clinton |
Posted: Mon Jan 19, 2004 5:08 pm Post subject: |
Should be ok then. Just make sure you install the BT patch for the XDA II. _________________ Lutz
DavidW Pocket GPS Moderator
Posted: Mon Jan 19, 2004 10:07 pm Post subject: |
I'd be concerned about using TomTom Navigator 1 on the XDA II - because the XDA II is a Pocket PC 2003 machine and Navigator 1 isn't officially Pocket PC 2003 compatible. Someone that tried Navigator 1 on a Pocket PC 2003 machine (I think it was an upgraded Dell Axim X5) appeared to hit trouble - though he hadn't got the latest 1.53 version (it seems that the 1.53 upgrade is no longer available from the TomTom site). I can't find the forum thread on this.
GPS wise, if you install GPS 2.09 (which I normally don't recommend, but I would in the case of an XDA II) it should install the necessary support for a Bluetooth GPS. I believe that's the whole point of the Bluetooth DLLs in the TomTom Wizard component that I'm usually so unhappy about. I don't think you need the unofficial patch in this case.
David |
