Pocket GPS World :: View topic - Other POIs
Other POIs
IanE
PostPosted: Mon Oct 09, 2006 11:31 pm    Post subject: Other POIs Reply with quote
Hi all,
I use MaFt's POIs from www.garminpoi.co.uk and I just wondered if anyone uses any others. I had a googls round for any more but nothing obvious turned up.
Ian
timber
PostPosted: Tue Oct 10, 2006 12:10 am    Post subject: Re: Other POIs Reply with quote
IanE wrote:
Hi all,
Ian
have a look here http://www.poihandler.com/index.asp
PaulB2005
PostPosted: Tue Oct 10, 2006 12:12 am    Post subject: Reply with quote
Also http://myweb.tiscali.co.uk/oldboy/TomTomPOI/index.html
rfarnell
PostPosted: Tue Oct 10, 2006 3:18 am    Post subject: Reply with quote
I hadn't spotted that one before it is rather good. The zip files have .csv files so no conversion is needed for the POI loader.
Thanks,
JR
Kevdb
PostPosted: Tue Oct 17, 2006 2:48 pm    Post subject: Reply with quote
Can anyone advise how the Custom POI's are listed in the Nuvi 310, the first batch I downloaded were in alphabetical order but when I add further ones they go straight to the end. I have even tried deleting them and then reloading but they are remain in the same jumbled order
mussey1
PostPosted: Tue Oct 17, 2006 3:46 pm    Post subject: Reply with quote
Kevdb,
You will find that they are listed in order of 'distance' from your current location.
I don't believe you can change it.
Mussey1.
nitelife
PostPosted: Tue Oct 17, 2006 4:20 pm    Post subject: Reply with quote
Dont forget: http://www.poidownload.co.uk/
POI's of every company in the UK, categorised.
Kevdb
PostPosted: Tue Oct 17, 2006 11:27 pm    Post subject: Reply with quote
Mussey1,
It is the headings I was really referring to ie Wickes, Comet etc rather than the individual addresses but thanks anyway
Kevdb
PostPosted: Tue Oct 17, 2006 11:33 pm    Post subject: Reply with quote
nitelife,
Can the POI's on this site be uploaded to my Nuvi ?
Swebster
PostPosted: Wed Oct 18, 2006 10:36 am    Post subject: Reply with quote
I'm a little confused over the use of POIs and speed camera database....
If I download the speed cameras and the latest poi from MaFt, which uploader can I use to load all pois onto i3? I have been using Ash10's camera manager - will this update POIs other than speed cameras? Do you need to drag the unzipped POIs into this, or do I need to unzip the file and then delete the unwanted POIs (understand that not all POIs and cameras will fit?).
I apologise if this q has been answered elsewhere - pse advise if this is the case...
Mant thanks
IanE
PostPosted: Fri Oct 20, 2006 10:45 am    Post subject: Reply with quote
Mant thanks
I use Ash's Camera Updater, and POILoader to manually update my memory card. I unzip MaFt's POIs to my POILoader directory and update that way.
Hope This Helps.
22.123 (18 Dec 24)
