Frosty Occasional Visitor
Posted: Mon Jan 19, 2004 8:40 am Post subject: Palm IIIxe & Garmin Etrex |
hi,
ive got a palm III and a garmin etrex (guess you figured that already) and tomtom citymaps... my pda is not communicating with the etrex... ive got a gender changer on the cables to join them... now i know for certain that the gender changer is doing it's job.. ive tried all the comms types that the gps can do... but the pda cant see the gps...
anybody got any ideas? |
lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Mon Jan 19, 2004 3:41 pm Post subject: |
The gender changer is normally inverting/mirroring the wires. That may not be what you want... Just because it fits physically doesn't mean the right wires will be connected... Are you familiar with RxD and TxD ? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Jan 19, 2004 11:35 pm Post subject: |
name a place where i can get a non inverting gender changer.. |
DavidW Pocket GPS Moderator
Posted: Mon Jan 19, 2004 11:56 pm Post subject: |
I'm not that familiar with the Palm - but on the Pocket PC, most serial cables are designed to be connected to a serial port on the PC to synchronise the PDA.
I suspect the same may be the case for your Palm - in which case the adapter you need should be a null modem, not just a gender changer.
David |
Posted: Tue Jan 20, 2004 1:33 pm Post subject: |
ok.. well heres a fun thing i also have a toshiba e310... ya dont happen to know anywhere i can ger a serial cable for it or any way i can driv ea usb-> serial adapter with it? |
jsiegel Occasional Visitor
Joined: 30/12/2002 16:58:25 Posts: 12 Location: United States
Posted: Sat Jan 24, 2004 9:25 pm Post subject: |
As a developer of GPS software for Palm OS, I run into this situation often. It is easily solved. You are halfway there with your gender changer - you just need one more little part - a null modem.
Radio Shack sells a nice little null modem - it's very inexpensive. Plug the null modem into the gender changer and put all of that onto the end of the Palm cable. That should then attach to your GPS.
The problem is that the receive and transmit lines need to be crossed since both the Palm and GPS are expecting to be connected to a "master" type of device like a PC. |
Posted: Sun Jan 25, 2004 3:38 pm Post subject: |
got a wiring diagram? |
Posted: Sun Jan 25, 2004 5:05 pm Post subject: |
The wiring diagram would tie ground to ground and cross transmit and receive. That's all a null modem does... |
Posted: Mon Jan 26, 2004 6:07 pm Post subject: |
cheers ;) |
Posted: Mon Jan 26, 2004 7:22 pm Post subject: |
right... cable made and works
cheers to all that helped ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
MemoPad Occasional Visitor
Posted: Tue Feb 03, 2004 5:51 pm Post subject: |
Hi Frosty,
Did you mean you can make your Toshiba e310 work with a GPS or just the Palm?
I got an offer of an e310 at a very good price. If if can be hooked up to a GPS via a serial cables, I will take it.
Thanks |
