Planner2 Occasional Visitor
Posted: Mon Oct 16, 2006 12:11 am Post subject: SD card space for TomTom6 |
Can anyone tell me how much SDcard space do you need for TomTom 6 running on a Ipaq HP5450. I have a 1GB SD card. Is that enough? |
alix776 Pocket GPS Moderator
Posted: Mon Oct 16, 2006 12:16 am Post subject: |
for the uk more thn enough _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Burn1 Occasional Visitor
Posted: Mon Oct 16, 2006 10:01 am Post subject: |
The whole of Western Europe takes about 900meg. I have GB and postcodes and France + Major roads of Europe and that is about 430meg. |
Posted: Mon Oct 16, 2006 9:52 pm Post subject: |
Hi Thanks for your reply. It is just that I noticed under the Western Europe map that there was one file 'Cline.dat' which is 924mb. Can I assume that all this file does not get loaded on the SD card? |
Posted: Mon Oct 16, 2006 9:56 pm Post subject: |
have you got uk only or the seamless european one _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Oct 16, 2006 10:38 pm Post subject: |
the seamless european. I didn't know you could get a only uk map for TT6. By the way can you use TT5 Uk map for TT6 if I can't get the european map on the Sd card? |
Posted: Tue Oct 17, 2006 3:18 pm Post subject: |
Hi Can anyone answer my questions above? |
Rybren Occasional Visitor
Posted: Tue Oct 17, 2006 9:11 pm Post subject: TT6 on 1GB SD |
I run TT6 with the seamless Western Europe map on a 1GB card. There's not a lot of extra space, but there is some.
I'm sure that you could also delete some files to free up more space, but I haven't gotten around to trying it yet. |
Posted: Wed Oct 18, 2006 12:06 am Post subject: |
When you load TT6 what is the process of installing only the UK map. At the moment there are files assciated with the western europe map that are in total over 1.5gb (i.e cline.dat 924mb, cnode.dat 295mb, faces.dat 253mb etc.). Does TT6 need all these files to be transferred to the SD card. If not, how do I load only the UK map? |
Oldboy Pocket GPS Moderator
Posted: Wed Oct 18, 2006 6:57 am Post subject: |
Planner2 wrote: | ... in total over 1.5gb (i.e cline.dat 924mb, cnode.dat 295mb, faces.dat 253mb etc.). | It seems you have the V5 Western Europe Map, as used on the 700, in which case you can't split it up.
The new V6 Map comes on an SD Card I believe, at 900MB.
It it is the downloaded MOWE as shown on TT's Website then you can install one of 7 Maps, ie GB.
It would help if we knew which copy you have. _________________ Richard
MarkHewitt Frequent Visitor
Joined: Nov 16, 2004 Posts: 1077 Location: Chester-le-Street & York
Posted: Wed Oct 18, 2006 10:42 am Post subject: |
Oldboy wrote: | Planner2 wrote: | ... in total over 1.5gb (i.e cline.dat 924mb, cnode.dat 295mb, faces.dat 253mb etc.). | It seems you have the V5 Western Europe Map, as used on the 700, in which case you can't split it up.
It would help if we knew which copy you have. |
The one which is available from the TomTom website i.e. "TomTom NAVIGATOR 6 - Software & Maps of Western Europe " is that one big seamless map or individual maps? |
MikeM132 Occasional Visitor
Joined: Oct 01, 2006 Posts: 17 Location: Bethlehem, PA (USA)
Posted: Wed Oct 18, 2006 4:53 pm Post subject: Re: SD card space for TomTom6 |
Planner2 wrote: | Can anyone tell me how much SDcard space do you need for TomTom 6 running on a Ipaq HP5450. I have a 1GB SD card. Is that enough? |
Most have given Europe answers. Just in case; TT6 takes about 977MB for US/Canada/Guam. |
Posted: Wed Oct 18, 2006 7:29 pm Post subject: |
MarkHewitt wrote: | The one which is available from the TomTom website i.e. "TomTom NAVIGATOR 6 - Software & Maps of Western Europe " is that one big seamless map or individual maps? | It looks as if it will do both!!
Quote: | Detailed maps of 20 countries across Western Europe on DVD: Door-to-door navigation in 20 Western European countries. Choose from a combination of regional maps or install one connected map of all of Western Europe on a 1GB memory card (not included). |
Posted: Fri Oct 20, 2006 1:34 pm Post subject: |
Can anyone tell me whether TT6 works okay with HP5450 Ipaq because I have installed the application using the CD and when I try to run it I get the following error message 'cannot find 'Tomtom Navigator' (or noe of its components). Make sure the path and filename are correct and all the required libraries are availalbe' Does anyone know why I get this message? |
Posted: Fri Oct 20, 2006 1:43 pm Post subject: |
does the 5450 run pocketpc2002 then i would think youll either have to upgrade the device to pocketp 2003 or 2003se from the hp website _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
