Pocket GPS World :: View topic - New to TomTom - help needed!
PostPosted: Mon Oct 16, 2006 3:00 pm    Post subject: New to TomTom - help needed! Reply with quote
ey up! i'm more of a garmin man myself but have recently acquired a tomtom go 300.
however, i have a few problems with it as follows:
i can't seem to connect it to a pc - i'm using a normal usb lead but does it need to be a special 'tomtom' one or something?
because of this i can't use tomtom home to be able to check latest firmware versions etc so can anyone tell me what the latest version is?
i can't seem to pull up full uk postcodes, it only allows for example bd15 as opposed ot bd15 9ax... any ideas?
and, finally, as i don't have a manual for it can anyone le me know the default pass key for connecting via bluetooth?!
cheers in advance
PostPosted: Mon Oct 16, 2006 3:18 pm    Post subject: Reply with quote
never mind.. i stuck the sd card into the card reader and tomtom home picked it up and has started downloading updates.
however, it still won't work with a full uk postcode... could it be out of date maps? i have v562.0
Border_Collie
PostPosted: Mon Oct 16, 2006 6:22 pm    Post subject: Reply with quote
Try putting an empty folder on your card and name it tomtom
It works on PDA's so with a bit of luck it may work on your 300. Smile
sgould
PostPosted: Mon Oct 16, 2006 7:10 pm    Post subject: Reply with quote
Are you looking in the right place to put the postcode?
After "Navigate to..." there's a postcode button on the 2nd page. If you put the code into the address it will only accept the first five digits. And don't use a space in the middle.
If still no postcode, check you have a folder called "zip". The postcode file "great_britain_postal" (or something like that) should be in it.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps
rugrat2
PostPosted: Mon Oct 16, 2006 7:50 pm    Post subject: Reply with quote
Also check in the root of your card for a flolder called zip about 8mbs...
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
rugrat2
PostPosted: Mon Oct 16, 2006 7:51 pm    Post subject: Reply with quote
PostPosted: Mon Oct 16, 2006 11:29 pm    Post subject: Reply with quote
cheers for the info.
there's an empty folder called TomTom already.
there's no 'zip' though - i presume that it is 'zip' as in zip code rather than a zip file? where would i get one from?
joedavid0
PostPosted: Tue Oct 17, 2006 12:54 pm    Post subject: Reply with quote
My TT GO will not work with full post codes even though I have the 6.15, I understand I need the 2006 map upgrade for which I've waited 10 months.
Regards
Oldboy
PostPosted: Tue Oct 17, 2006 6:49 pm    Post subject: Reply with quote
The Full Postcode first came out with V5 Maps.
22.064 (26 Jun 24)
