Pocket GPS World :: View topic - New way to do custom POI warnings in TomTom 5 & 6
Goto page Previous  1, 2, 3, ... 33, 34, 35  Next
PostPosted: Sun Oct 15, 2006 12:43 am    Post subject: Reply with quote
You would chose to not select "warn only if POI on route" IF you drive around without a destination set and still want speed camera warnings. If you always drive with a route planned then you can select this box and get warnings, either way this setting will not alter or affect your problem getting the ogg warning files working.
If you have the files in the correct place, and of the correct names, use the advanced planning option to set a route past a few known speed cams in the local area and listen to what happens (set the replay speed to 100%) - this saves bothering taking the car out this late! - Mike
rugrat2
PostPosted: Sun Oct 15, 2006 1:27 am    Post subject: Reply with quote
This is a great way to set warnings and still have bells and whistles..... :D
Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go..
korndog
PostPosted: Sun Oct 15, 2006 2:06 am    Post subject: Reply with quote
markmcrobie wrote:
Yes, they are all name the same (.bmp, .ov2 and .ogg, eg gatso_20.bmp, gatso_20.ogg, gatso_20.ov2) and they are all in my Great_Britain folder.
you have to put "pocketgps_uk" in as well
Paul
TomTom Go 600
gpssparky
PostPosted: Sun Oct 15, 2006 11:19 am    Post subject: Reply with quote
markmcrobie wrote:
Ok, thanks
I have a curiousity question - Why would you choose anything other than "only warn if on route"? Why would you want to be warned of something not on your route?
If you are travelling with no route planned in tomtom it will not warn you about a poi if you have "only warn if on route" checked
Everywhere and nowhere
Tomtom Go 540 Live - That's it.
Noony
PostPosted: Sun Oct 15, 2006 11:37 am    Post subject: Reply with quote
One reason to warn when 'not on route' is when you have cancelled the route, you still get the warning even if you are not being guided somewhere.
doodaa
PostPosted: Sun Oct 15, 2006 11:55 am    Post subject: with text to speech? Reply with quote
Is there anything similar one can do to use text to speech instead? (on a 910)
annoyingly, their speed camera plus service doesn't allow selecting sounds (it's not configureable), and they don't turn up in the poi list, so I guess something similar could be done. I wish it could just synthesize a text.
PostPosted: Sun Oct 15, 2006 12:13 pm    Post subject: Re: with text to speech? Reply with quote
If you use a third-party camera database (like the one from here), you CAN use the Text to Speech to create yout own alerts
Instructions HERE
(Note that they will only work if you are also using a TTS voice for the navigation prompts)
doodaa
PostPosted: Sun Oct 15, 2006 12:23 pm    Post subject: Reply with quote
Yes, I've seen that, as I have another free database installed in the past.
I just registered to TT's database because of the realtime updates feature.
Right now I'm digging for what changes when I set that option for other POIS. If I could figure out where and in what format the data is stored... I'm expecting the file to be the map .cfg file, which I cannot tell what format is being used to store in it.
bobthebuilder
Banned
PostPosted: Sun Oct 15, 2006 12:39 pm    Post subject: Reply with quote
Also works perfect on the Nokia N80 & N73 Mobile phone.
Must remember ellio7's tip that you have to re set each gategary re warn when near otherwise you just get 3 warning beeps
Tom Tom have really come up with the goods on their latest version.
And many thanks to pocketgps for the camera database and tips, plus many thanks to Rays Tom Tom site for Liz's voice warnings
:D :D :D
doodaa
PostPosted: Sun Oct 15, 2006 12:40 pm    Post subject: not in uk Reply with quote
I forgot to mention I don't live in the UK sorry. Else I'd be happy to subscribe to your speed camera lists =)
doodaa
PostPosted: Sun Oct 15, 2006 2:06 pm    Post subject: Reply with quote
Yes, it seems the TTS warnings are stored at the end of the MapSettings.cfg file. Unfortunately the formatting is a bit weird, so I'm not too sure how it refers to the poi file (yet)
furryfred
PostPosted: Sun Oct 15, 2006 9:24 pm    Post subject: Reply with quote
I've downloaded the data.chk file for Liza and it is good!
I now am getting ready with the .ogg files and note the comments about re-naming them to the Pocketgps_uk_ ov2 and bmp files.
Most is self explanatory but which of the ov2 files refers to the simple gatso, mobile or specs (with no stated limits). For gatso there are ...._gatso_tba and ..._gatso_var. I assume it is ...gatso_tba - but am I right?
If I am then I assume that it will be ...mobile_tba and ...specs_tba.
Please confirm or correct me[b]
Furry Fred
(a very very nice, handsome and generous gentleman who is really rather modest, shy and retiring!)
They didn't make many like him - and now they've lost the mould!
PostPosted: Sun Oct 15, 2006 9:36 pm    Post subject: Reply with quote
The .ogg file name must match the .bmp and .ov2 file - I will post a full list later.
For the record though this even works on TomTom Navigator version 5 - Just checked it out on my main PDA and its great! - I hate to think how much time was expended with all the extra files and programs that were created to get around what was a simple fix!
Mike
korndog
PostPosted: Sun Oct 15, 2006 10:11 pm    Post subject: Reply with quote
for both var and tba you will use the gatso warning, just use the same file for both but give it 2 different names,ie pocketgps_uk_gatso_tba.ogg and pocketgps_uk_gatso_var.ogg.
It may seem easier to just knock off the pocketgps_uk off the camera file instead of adding pocketgps_uk etc to the ogg files but it'll make it hard work when you have to update the cameras next month
Paul
TomTom Go 600
furryfred
PostPosted: Sun Oct 15, 2006 10:32 pm    Post subject: Reply with quote
Thanks. Done it - now to try it!
I have alterered the .ogg file name as these may well be more longer lasting than when I upgrade my ov2 and bmp files every month and would have to do it to all them every time I downloaded.
Can someone recommend me a programme that will make an .ogg file for say a .wav so I can try putting one in for Witherspoons!
Furry Fred
Page 2 of 35
23.011 (02 Jan 25)
