Pocket GPS World :: View topic - Maps from 269+ onto my c710???
Courior
PostPosted: Fri Oct 13, 2006 1:50 pm    Post subject: Maps from 269+ onto my c710??? Reply with quote
I had a Mio 269+ which had slovakia and hungary among other eastern european countries. I now have a C710. Can i take the maps from the 269+ DVD and stick them on my C710?
Thanks in advance!!
lbendlin
PostPosted: Sat Oct 14, 2006 4:21 am    Post subject: Reply with quote
Technically yes. But why do you want to go through the Navigon pain when you can have the much better iGO?
Lutz
TomTom/TeleAtlas NAVTEQ
Courior
PostPosted: Sat Oct 14, 2006 3:55 pm    Post subject: Reply with quote
I dont understand what you mean about the navigon.. my old navigator was also a Mio. did they run different softwares (except for the obvious version number difference). Thanks for the help!
lbendlin
PostPosted: Sat Oct 14, 2006 7:06 pm    Post subject: Reply with quote
The older Mios run MioMap v2 ( Navigon ). The newer run MioMap v3 (iGO).
Lutz
Courior
PostPosted: Sat Oct 14, 2006 11:40 pm    Post subject: Reply with quote
Ah i see. good to know that.. ok, i have the iGO dvd, with the eastern european maps on it. I have blue toothed the map file into the relevant directory on my C710 and it says that its locked. how do i go about unlocking it? its just 2 maps that i want.
lbendlin
PostPosted: Sun Oct 15, 2006 1:46 am    Post subject: Reply with quote
maps are locked to the SD card. You have to put the SD card into the 710, not copy the maps to the 710.
Lutz
Courior
PostPosted: Sun Oct 15, 2006 9:10 pm    Post subject: Reply with quote
I have tried creating a Maps folder on an SD card and putting them in there but to no avail. so far i have downloaded the IGO dvd and have copied the 2 map files i want to my C710 (didnt work) and then deleted them and put them on sd card (didnt work).. any advice on what to do would be so much appriecated!! Thanks in advance!!
CompufixUK
PostPosted: Sun Oct 22, 2006 1:03 am    Post subject: Reply with quote
The maps from V2 (.map extension) and the ones from V3 (.fbl extension) are incompatible, unless you wish to dig into them and alter them somewhat. Thats primarily why they wont work. Try altering the file extension of the V2 maps and watch the result
Morkin
PostPosted: Tue Oct 24, 2006 11:45 pm    Post subject: Reply with quote
Courior, you cannot just copy the maps to your sd-card or your flash disc.
The maps are locked because you don't have the correct license.db on your Mio.
I am guessing that you have Western Europe on your Mio.
So you have a lincense.db for Western Europe only.
Mio C710 unlocked.
Miomap deleted. - iGo with Western Europe on Flash disk.
Website: http://mio.digiwalker.googlepages.com/
Courior
PostPosted: Wed Oct 25, 2006 6:55 pm    Post subject: Reply with quote
Thanks, that has been most helpful. Can i copy the licence over from the igo software and then it will work? as the igo software has the same maps that the c710 has plus more.
lbendlin
PostPosted: Wed Oct 25, 2006 7:54 pm    Post subject: Reply with quote
you can use iGO SD cards in the 710. You cannot copy the contents of the SD card over to the flash though. (You can copy it but it won't work)
Lutz
22.094 (25 Sep 24)
