Pocket GPS World :: View topic - Co ordinate Converter
Technical
PostPosted: Thu Oct 12, 2006 8:09 pm    Post subject: Co ordinate Converter Reply with quote
I have been able to obtain a Excel spreadsheet with all the static, mobile and temp camera locations in my county. The excel sheet has a descriptive location followed by 2 x 6 diget referance data. I think these are os referances. I have been able to briefy verify that there are a number of new sites not shown in the early oct 06 release. Does anyone know of a programme that can be dowloaded to convert this data into the co-ordinates required for submission to the database? :o
BMW330
PostPosted: Tue Oct 17, 2006 3:16 pm    Post subject: Re: Co ordinate Converter Reply with quote
Technical wrote:
Show me some sample data and I might be able to help...
Technical
PostPosted: Wed Oct 18, 2006 8:22 pm    Post subject: Re: Co ordinate Converter Reply with quote
BMW330 wrote:
Technical wrote:
Sample data as requested
APPROXIMATE MAP REFERENCES
START END
SiteName Easting_Start Northing_Start Easting_End Northing_End
A3102 Snow Hill, Hilmarton 401880 175750 401790 176740
A3102 Lyneham 402227 179066 402460 178636
BMW330
PostPosted: Wed Oct 18, 2006 9:12 pm    Post subject: Re: Co ordinate Converter Reply with quote
Need 1 or 2 more points please...
BMW330
PostPosted: Wed Oct 18, 2006 10:04 pm    Post subject: Re: Co ordinate Converter Reply with quote
Actually, don't worry.
I think your data might be inaccurate as both co-ordinates are off the road (I used averages for the conversion).
Snow Hill http://maps.google.com/?q=51.48514722,-1.974963889&z=17
Lyneham http://maps.google.com/?q=51.50857778,-1.967625&z=17
Calculator is here:
http://www.carabus.co.uk/jscalculators.html
(select "Locator Calculator", then British as the grid)
coconut
PostPosted: Thu Oct 26, 2006 9:21 am    Post subject: They ARE OS Grid References ! Reply with quote
Actually guys I think you will find that these are perfectly valid 12 figure OS grid References - accurate to 1 metre !
I have only checked the first one : 401880 175750 which is about a 1/4 mile North of Hilmarton, on the A3102 after it crosses a stream !
The first block of 6 figures are the Eastings and the second block of 6 are the Northings. The first number from eack block identify the Map Sheet ( 100 Km ) - In the above example 4 1 converts to map sheet SU, so the full Grid Ref is SU 01880 75750.
You can decode the Uk map sheets with the following :
Number the grid starting from the bottom left corner ("0,0" ) and you will see how Map sheet SU is arrived at from "4,1" - i.e "4" across ( Eastings ) and "1" up ( Northings ). Along the corridor & up the stairs !
[/img]
iPhone SE, TomTom Go 5000, Garmin Zumo XT.
Oldie
PostPosted: Thu Oct 26, 2006 8:15 pm    Post subject: Reply with quote
My POIConverter program http://rjdavies.users.btopenworld.com/html/poiconverter.html will read files that contain Eastings and Northings. Have a look at AutoRoute Pushpins in the Help file after you have installed it.
Various TomToms, Garmin eTrex Legend, GPSMAP 60CSx, Oregon 550t, Forerunner 405
22.093 (18 Sep 24)
