Pocket GPS World :: View topic - Two more TT1 V2 buggets?
wibbly
PostPosted: Wed Oct 11, 2006 8:44 am    Post subject: Two more TT1 V2 buggets? Reply with quote
- Sometimes, when I turn it on, I get the post reset splash screen and drums. I guess this means it crashed when I last switched it off? :-(
- I set the night-time colour scheme the same as the day time one (Brittanica, but with lower brightness). Seemingly unassociated with the bug above, my TT just seems to randomly forget the nightime scheme are revert to anther one.
- Sound mysteriously stopped working one time I switched on, and then started again whilst travelling (as I reported in the recent 'sound problems' thread)
Anyone else seem these?
iancjc
PostPosted: Wed Oct 11, 2006 4:14 pm    Post subject: Reply with quote
heard the drums a couple of times - mostly after I've been fiddling with the sd card
1 bug I have had was turning on - the tomtom screen would come on and loading bar would finish and then after 5 seconds it would switch off.
I thought the sd card had broken but it was ok when I put it in my pc - to be safe I copied it onto another sd card and the same thing happened... I then inserted my original sd card in the v2 and all was fine...
the unit must have corrupted a file on the sd card..
then copied this onto my sd card and it works on the non tomtom card again - had to add the pois etc back... now have a backup in home....
SO YOU HAVE BEEN WARNED don't use the original sd card and do keep a backup....
TTN6.03 tomtom 7.xx (one)
PostPosted: Wed Oct 11, 2006 7:07 pm    Post subject: Re: Two more TT1 V2 buggets? Reply with quote
The Classic does that as well.
TT Via 135 App 12.075: Europe Map v1135
TuurG
PostPosted: Thu Oct 12, 2006 12:06 am    Post subject: Re: Two more TT1 V2 buggets? Reply with quote
That happens after you have had the ONE connected with USB, or when you start the ONE without SD inserted
GO1005
MGC GT 1968
MGB Cabrio 1973
dgwallace
PostPosted: Thu Oct 12, 2006 12:07 am    Post subject: Reply with quote
i am wondering if i am having a similar problem, i am a newbie to sat nav technology and now it will not even switch on at all. but the journey i made tonight it worked fine no issues at all, but i tried to switch it on since and have had no joy
Eldar
PostPosted: Thu Oct 12, 2006 12:15 am    Post subject: Reply with quote
tried reset?
dgwallace
PostPosted: Thu Oct 12, 2006 12:20 am    Post subject: Reply with quote
cheers fella, didnt realise it was that technical! Embarassed
is that something than i can expect to happen often, i have only had it since monday
Eldar
PostPosted: Thu Oct 12, 2006 12:55 am    Post subject: Reply with quote
If you have GO500, 700, 510, 710, 910 or ONE then yes, carry a paperclip with you. Not sure about ONE v2 and Rider, cause the former is too new and the latter is not very popular.
dgwallace
PostPosted: Wed Nov 15, 2006 12:23 am    Post subject: Reply with quote
just an update...
maybe its just a coincidence, but since i have upgraded to v6.52 or whatever it was (through TT Home) I am not having this issue any more.
Eldar
PostPosted: Wed Nov 15, 2006 12:37 am    Post subject: Reply with quote
dgwallace wrote:
just an update...
miracles do happen....
22.101 (03 Oct 24)
