wibbly Frequent Visitor
Posted: Wed Oct 11, 2006 8:44 am Post subject: Two more TT1 V2 buggets? |
- Sometimes, when I turn it on, I get the post reset splash screen and drums. I guess this means it crashed when I last switched it off? :-(
- I set the night-time colour scheme the same as the day time one (Brittanica, but with lower brightness). Seemingly unassociated with the bug above, my TT just seems to randomly forget the nightime scheme are revert to anther one.
- Sound mysteriously stopped working one time I switched on, and then started again whilst travelling (as I reported in the recent 'sound problems' thread)
Anyone else seem these? |
iancjc Frequent Visitor
![](modules/Forums/images/avatars/avatar_sp_034.jpg)
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Wed Oct 11, 2006 4:14 pm Post subject: |
heard the drums a couple of times - mostly after I've been fiddling with the sd card
1 bug I have had was turning on - the tomtom screen would come on and loading bar would finish and then after 5 seconds it would switch off.
I thought the sd card had broken but it was ok when I put it in my pc - to be safe I copied it onto another sd card and the same thing happened... I then inserted my original sd card in the v2 and all was fine...
the unit must have corrupted a file on the sd card..
then copied this onto my sd card and it works on the non tomtom card again - had to add the pois etc back... now have a backup in home....
SO YOU HAVE BEEN WARNED don't use the original sd card and do keep a backup.... _________________ -----------------------------------------------------------
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one) |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Wed Oct 11, 2006 7:07 pm Post subject: Re: Two more TT1 V2 buggets? |
wibbly wrote: | - I set the night-time colour scheme the same as the day time one (Brittanica, but with lower brightness). Seemingly unassociated with the bug above, my TT just seems to randomly forget the nightime scheme are revert to anther one. | The Classic does that as well. _________________ Richard
TuurG Frequent Visitor
![](modules/Forums/images/avatars/350681644c94264ae694.jpg)
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Thu Oct 12, 2006 12:06 am Post subject: Re: Two more TT1 V2 buggets? |
wibbly wrote: | - Sometimes, when I turn it on, I get the post reset splash screen and drums. I guess this means it crashed when I last switched it off? :-(
| That happens after you have had the ONE connected with USB, or when you start the ONE without SD inserted _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
dgwallace Lifetime Member
Posted: Thu Oct 12, 2006 12:07 am Post subject: |
i am wondering if i am having a similar problem, i am a newbie to sat nav technology and now it will not even switch on at all. but the journey i made tonight it worked fine no issues at all, but i tried to switch it on since and have had no joy |
Eldar Pocket GPS Moderator
Posted: Thu Oct 12, 2006 12:15 am Post subject: |
tried reset? |
Posted: Thu Oct 12, 2006 12:20 am Post subject: |
cheers fella, didnt realise it was that technical!
is that something than i can expect to happen often, i have only had it since monday |
Posted: Thu Oct 12, 2006 12:55 am Post subject: |
If you have GO500, 700, 510, 710, 910 or ONE then yes, carry a paperclip with you. Not sure about ONE v2 and Rider, cause the former is too new and the latter is not very popular. |
Posted: Wed Nov 15, 2006 12:23 am Post subject: |
just an update...
maybe its just a coincidence, but since i have upgraded to v6.52 or whatever it was (through TT Home) I am not having this issue any more. |
Posted: Wed Nov 15, 2006 12:37 am Post subject: |
dgwallace wrote: | just an update...
miracles do happen.... |
