Jasoon Occasional Visitor
Posted: Sun Aug 13, 2006 5:51 pm Post subject: Navman icn 510 help |
Can anyone help me...
I've installed the speed camera files on my 510 but I cant seem to view them there's no category on the points of interest page and when I have a look at the map other poi are there but not the speed cameras
I've install the files using the guide on how to install
the navman 510 is v3.00.1008 |
Posted: Tue Aug 15, 2006 11:56 pm Post subject: |
Anyone help with this one? |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Wed Aug 16, 2006 7:24 am Post subject: |
Have you Activated them?
Have you set them up as per Page 29 of the Manual? _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Unhban Occasional Visitor
Posted: Wed Aug 16, 2006 2:34 pm Post subject: |
Wasn't there a problem in one of the files in the latest issue of the Safety Camera POI which got corrected soon after the original issue. Something like there was an SC in Ireland included and you had to delete that line to make it work (have a search)?
Perhaps you downloaded the problem version?
I can only suggest download the latest version and start again.... |
Posted: Thu Aug 17, 2006 5:48 pm Post subject: |
The version i downloaded was the one thats up for download now |
cleggie Occasional Visitor
Joined: Aug 28, 2006 Posts: 36 Location: South Yorkshire UK
Posted: Wed Aug 30, 2006 4:45 pm Post subject: |
the speedcam poi is not in with the built in pois,its in a place under my poi along with my data
any other poi,s you add are also in there |
Posted: Tue Oct 10, 2006 12:44 pm Post subject: |
no poi under my poi along with my data when i put smart ST on its listed as being on the device  |
nortonbeak Regular Visitor
Joined: Oct 08, 2005 Posts: 186 Location: North East, England
Posted: Tue Oct 10, 2006 1:57 pm Post subject: |
Its a bit of a mystery.
Just try a fresh install. _________________ Navman ICN 520
512 Mb Cygnet SD card
Smart ST 2005 + SP 1 |
Posted: Tue Oct 10, 2006 2:18 pm Post subject: |
ive tried deleting it and re-installing it ,if thats what you mean nortonbeak |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Tue Oct 10, 2006 2:51 pm Post subject: |
Jasoon wrote: | Anyone help with this one? |
Jasoon I'm sure you know that the uploaded POIs should be on your SD card. Check, as follows: Take out SD card from device and connect it to your computer. Have a look inside the folders shown - the one called My POIs is the one to interest you. Open it and see if the files are actually there.
If they are, go to your device and check Settings - Alerts - Active POIs and check to see that they are all described as 'Active'.
If not, go to Settings - My Data - My POIs and ensure all the boxes are ticked.
Forgive me if you have already done all this, but it's worth checking  _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Tue Oct 10, 2006 10:37 pm Post subject: |
still no joy
it was on the card but not in the my poi folder so ive mooved it to there but still no joy  |
Posted: Wed Oct 11, 2006 12:03 am Post subject: |
Jasoon wrote: | still no joy
OK. Now you have put them in My POIs, have you checked the next part?
[quote]If they are, go to your device and check Settings - Alerts - Active POIs and check to see that they are all described as 'Active'. [/quote] _________________ Gee-Pee
Posted: Wed Oct 11, 2006 3:51 pm Post subject: |
yep ive done that and there all active |
Posted: Wed Oct 11, 2006 4:18 pm Post subject: |
Jasoon wrote: | yep ive done that and there all active | Just to recap.
1. All the speed cam POIs are on your SD card.
2. They all show as being activated.
3. Smart ST confirms the data has been downloaded to your device
4. you have followed the PGSW instructions to the letter and that includes loading the speed cam icons
Having done all that they still do not work
Have you actually driven past a speed cam to test it
Is it possible that you have loaded the camera data but not the speed cam icons
I just do not understand.....  _________________ Gee-Pee
