Pocket GPS World :: View topic - Speed-Based Icons for CP6
Goto page Previous  1, 2
iankb
PostPosted: Mon Aug 28, 2006 5:35 am    Post subject: Reply with quote
Not really. The only option would be to bring up the old camera warning screen, but that is far worse than the new alerts, since it obscures the screen, and holds back turn instructions, for 30 seconds.
Ian
iPaq 2210
Globalsat BT-338
Seidio G2500 Amplified Vent Mount
CoPilot 6, GPS Tuner 4.2, Navio 3.01
BMW 330ci Sport
iankb
PostPosted: Mon Aug 28, 2006 5:44 am    Post subject: Reply with quote
Since the audible voice warning is always a WAV file, even if TTS has been selected, I suppose it must be possible to find the related file, and delete it. There is an Ogg Vorbis file called safetycam.ogg, so that is probably the file to remove. I've no idea what effect that will have, so I would back it up, just in case.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
nivek22
PostPosted: Thu Aug 31, 2006 4:51 pm    Post subject: Reply with quote
Just a quick thanks to iankb for the icons Thumbs Up
Prior to this camera download i wasn't seeing the camera icons in planning mode.
I still don't see them in planning mode but they do appear in demo mode and while driving - so no problem.
iankb
PostPosted: Thu Aug 31, 2006 5:32 pm    Post subject: Reply with quote
That's an interesting option. Planning a route to avoid the cameras. Smile
However, the presence of cameras with known speed limits does give an indication of the speed that the stretch of road is actually capable of, and is maybe a potential aid to a navigation package in calculating the quickest route. i.e. An A-class road with cameras is probably a faster road than an A-class road without, or they wouldn't have put the cameras where they did.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
DrRobin
PostPosted: Tue Oct 03, 2006 11:04 am    Post subject: Reply with quote
I have loaded in the new cameras by type (safetycamera_*.*) and added icons. They are in there but I can't see them on the screen although the alert pops up and I can search for them by POI. If I load them in again with a different name (speed*.*) then they appear on the map, but appear twice.
I am running the latest version and have cleared out the ao*.* files first. Can anyone help?
DrRobin
nivek22
PostPosted: Tue Oct 03, 2006 12:01 pm    Post subject: Reply with quote
This sounds like the issue that I have with the 'Safetycamera_*.*' icons.
I've now noticed that they're only visible when moving faster than 5 mph. Although they do show when running the demo.
iankb
PostPosted: Tue Oct 03, 2006 2:22 pm    Post subject: Reply with quote
The camera icons as provided by this forum are created for TomTom, and have too many colours for CoPilot. I created some 8-bit colour icons which work fine, but you could always ask the forum administrators to include CoPilot-compatible icons within the CoPilot downloads. They are welcome to include my icons if they want, although they are designed to maximise the display of the speed, rather than some representation of a camera. See my avatar for examples.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
DrRobin
PostPosted: Tue Oct 03, 2006 11:38 pm    Post subject: Reply with quote
Nivik, Ian,
Thanks for the replies. My Copilot does work correctly in Demo mode and now I only have one copy of the camera db installed I will try it tomorrow to see if it works when doing more than 5 MPH.
Would be nice if ALK fixes the problems/issues with the pop up alert, but I am really pleased with the software so can't complain.
DrRobin
:D
iankb
PostPosted: Wed Oct 04, 2006 2:34 pm    Post subject: Reply with quote
iankb wrote:
I created some 8-bit colour icons which work fine ...
Correction: They are 4-bit (i.e. 16-colour) bitmaps.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
DrRobin
PostPosted: Mon Oct 09, 2006 3:26 pm    Post subject: Safety Camera Icons not showing up. Reply with quote
Thanks Ian,
I have 16 colour bitmaps and the latest patch 6.0.1.68. I have just re-loaded everything as my memory card failed. I get the icons in demo mode and if I search for them as a POI, but whilst I get the new style safety camera alert, I never see the icon on the screen.
Other POI's I have loaded show up fine, both on planning and on 3D. Can anyone help?
TIA
DrRobin
DrRobin
PostPosted: Mon Oct 09, 2006 3:47 pm    Post subject: Safety Cams & Icons Reply with quote
I have noticed that the only time I can see the camera on the screen including planing is when it is co-located with another POI, in which case the multi icon appears. If you double click then it gives the camera details.
If I load the camera db in again with a different name then I see them all but with the multi-icon displayed as there is two camera in the same place.
I not sure if this helps?
DrRobin
DrRobin
PostPosted: Mon Oct 09, 2006 9:51 pm    Post subject: Safety Cameras Reply with quote
Hi All,
I have removed all POIs again and this time loaded the safety cameras as speedc*.*. I have show POIs enabled and the new safety camera alert enabled.
Now what happens is that I see the safety camera icons on the screen in all screens, stationary, driving and planning.
When I approach a safety camera I get an spoken warning and when just about on top of it a sound but I don't get the little yellow pop up screen.
I am quite happy to dispense with the little yellow pop up alert screen as in its present form it offers little and it is much better to see the icons.
I assume there is something in the ov2 file which tells Copilot that the file is a safety camera.
Enjoy
DrRobin
:D
iankb
PostPosted: Mon Oct 09, 2006 10:00 pm    Post subject: Re: Safety Cameras Reply with quote
Nothing in the file. Simply the fact that the filename begins with 'safetycam'.
Ian
iPaq 2210
Globalsat BT-338
BMW 330ci Sport
fluffball
PostPosted: Fri Apr 20, 2007 4:46 pm    Post subject: Reply with quote
I do not see safety camera icons in planning mode either (using safetycamera... naming). Contacted ALK who gave me some more camera bitmaps to try but that didn't solve anything. They seemed surprised.
Page 2 of 2
23.053 (21 May 25)
