Pocket GPS World :: View topic - Speedcams Builder for Mio Cxxx Series
Goto page Previous  1, 2, 3, ... 15, 16, 17  Next
Sallyann
PostPosted: Sun Oct 08, 2006 11:01 am    Post subject: Reply with quote
GPSBear wrote:
One question. If you wanted to load UK & Europe cams would you merge the two files into the "UK" one and then run your utility?
I haven't tested this, but if you did it and the additional file was in exactly the same format as the PGPSW one I would expect it to show all the 'foreign' cameras in the correct place but with the wrong speed and/or type.
One of the complications of the Mio format is that it has a separate code for each country and you have to tell it what country to use for each file. As mentioned elsewhere I haven't worked out all the country codes yet - I don't expect that's a huge job but I have other things to do. Another problem is that I wanted this to be a one-click program so anyone could use it. If you have used the autovelox program with multiple countries you will see just what I was trying to avoid.
Sal
alix776
PostPosted: Sun Oct 08, 2006 11:06 am    Post subject: Reply with quote
just a quicky to let you know it wes me who stickied it
device Lumia 950 xl
Dilcymro
PostPosted: Sun Oct 08, 2006 11:58 am    Post subject: Reply with quote
Wel done Sal, you have a sticky. Bouncing
I am going to print your instructions off now and have a go.
Regards....Dil
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Dilcymro
PostPosted: Sun Oct 08, 2006 1:59 pm    Post subject: Reply with quote
Ok, I think I have done everything right setting up this file, I checked the folder after and it only showed the new mtc file. Is there anyway of checking on the 510 itself if they are there or not?
Thanks....Dil
Garmin Nuvi 2415
Sallyann
PostPosted: Sun Oct 08, 2006 2:28 pm    Post subject: Reply with quote
Thanks....Dil
Only by looking at a place where you know there is a camera. Go to the middle of Manchester or London and zoom in.
Sal
Wroey
PostPosted: Sun Oct 08, 2006 5:11 pm    Post subject: Reply with quote
Or get someone who lives local to pop down the road to see if it is still there! Wink Just joking!
MIO C710 Since Sep 2006
topgazza
PostPosted: Sun Oct 08, 2006 5:48 pm    Post subject: Reply with quote
I don't have a bluetooth facility on my PC....is this the only way to do this ?
TomTom 720
Nokia Lumia 800 with Nokia Maps, iPhone 4S with Apple Maps (sigh)
GPSBear
PostPosted: Sun Oct 08, 2006 6:17 pm    Post subject: Reply with quote
Loaded PGPSW cams with 102. Today going past a site where I have seen a mobile camera in the past the Mio rebooted itself. Need to trawl through the cams and see if it is a reported position - Will report back if it is.
Sallyann
PostPosted: Sun Oct 08, 2006 7:28 pm    Post subject: Reply with quote
That's the only way anyone has found to get inside the Mio.
But you can get a Bluetooth USB dongle and software for less than £20.
Sal
topgazza
PostPosted: Sun Oct 08, 2006 11:44 pm    Post subject: Reply with quote
Thats true, you can get a decent 2.0 Bluetooth dongle for about £8.99 from the likes of ebuyer etc etc. XP Pro sees them without any trouble. I shall be buying one......
TomTom 720
Dilcymro
PostPosted: Mon Oct 09, 2006 1:58 pm    Post subject: Reply with quote
Nah, I did better than that, I put in a local town and then ran my finger over the touch screen along the main road where I knew with using the nuvi where the cameras should be and low and behold , there they were, I also checked
some other roads wher the mio never used to warn me and again the cameras were popping out the map...brilliant. Just hope they work when I go for a drive that way.
I think our sall is brill. Love it
Regards...Dil
Garmin Nuvi 2415
Dilcymro
PostPosted: Mon Oct 09, 2006 2:10 pm    Post subject: Reply with quote
Bye the way sall, When the speedcams get updated as they do, I take it we just do the same with the new files and copy over to the mio in the same way.
Also , when I downloaded the speedcam files there was the usual bitmap ones there, I transferred these along with the other one, do I actually have to do this or just the asc ones. I wasnt sure as I thought these were required for the camera icons?
Thanks ...Dil
Garmin Nuvi 2415
Peasemold
PostPosted: Mon Oct 09, 2006 2:23 pm    Post subject: Reply with quote
Wroey wrote:
a got TWO FATAL ERRORS and an automatic restart..
Maybe this is a V3.2 problem, as I had one of those and I have not updated to the PGPSW database. I might flag it up over at PDAMill.
Peasemold
Sallyann
PostPosted: Mon Oct 09, 2006 2:41 pm    Post subject: Reply with quote
Yes, just copy the new file over the new one.
The Mio always uses its own built-in icons, so you don't need any others. As I noted in the instructions you can copy all of the files to the Mio Builder folder if you like, but it will only use the one it needs.
Sal
Sallyann
PostPosted: Mon Oct 09, 2006 3:12 pm    Post subject: Reply with quote
Peasemold
That's very interesting. It will be interesting to see if anyone else reports a crash using the Mio database. It would be a shame if there is a problem with 3.2 after we have waited so long for it.
Sal
Page 2 of 17
22.063 (19 Jun 24)
