Pocket GPS World :: View topic - garmin i3 freezes
garmin i3 freezes
dave1976
PostPosted: Sun Oct 08, 2006 5:14 pm    Post subject: garmin i3 freezes Reply with quote
hi after installing some poi (speed cams) into my new garmin i3 it has failed to work in every aspect......it just freezes on the main page nothing else happens ...ive tryed resetting it by pressing the 3 buttons at start but with no affect.... the problem seems to be with the memory card i think coz when i take it out it works with minimum affect of coz....but as soon as i put memory card back in same old same old it just freezes straight away.... ive been thinking of buying new memory card but im unsure weither this alone will fix my problems...ps plz help because ive not even used the damn thing that much and ive already broke it all because i wanted 2 put a few speed cams in............ Sad
mussey1
PostPosted: Sun Oct 08, 2006 11:44 pm    Post subject: Reply with quote
Hi Dave,
Does your i3 have the maps on the memory card or on the internal memory?
Mussey1.
dave1976
PostPosted: Mon Oct 09, 2006 4:30 am    Post subject: Reply with quote
hi mussey my garmin only has very basic maps on internal memory ...only main roads such as A roads no side streets..
PaulB2005
PostPosted: Mon Oct 09, 2006 9:02 am    Post subject: Reply with quote
Can you explain thius further. All UK I3s should have full UK mapping down to the smallest of side roads.
Do you have detail set to minimum?
mussey1
PostPosted: Mon Oct 09, 2006 9:38 am    Post subject: Reply with quote
Dave,
Are you in thr Republic of Ireland?
I know that only major towns and cities are fully mapped there, one in the rural areas only main roads are maped.
Mussey1.
dave1976
PostPosted: Mon Oct 09, 2006 3:14 pm    Post subject: Reply with quote
mussey1
no m8 im in the uk....
dave1976
PostPosted: Mon Oct 09, 2006 3:17 pm    Post subject: Reply with quote
i3 has every road and every map when i could use it with the memory card in and it was working prop...but now its nor working the only way i can get it on is if i take memory card out and then all im left with is a very basic map with only lets say a major rd .....no addresses no side streets..
zogman
PostPosted: Mon Oct 09, 2006 3:47 pm    Post subject: Reply with quote
dave, have you loaded any software or poi's onto the i3...if you have you might have accidently corrupted the mapping on the card...
mk_graham
PostPosted: Mon Oct 09, 2006 3:53 pm    Post subject: Reply with quote
Dave,
When you load POI's do you load them direct to the i3 or to the card in a separate reader?
If to the card, do you have a back-up of your card that dates back to before you loaded POI's to it?
If so suggest copying this back to the card.
When you put your card into a reader attached to your PC, does it read okay?
If yes, what files are on it?
Do you have other POI's installed?
Suggest you try overwriting the safety camera POI's (any others) using a small or single-entry POI.
Appreciate that it may take you a little longer, but any chance you could always type words in full as being an old(er) git, I hve trble rding txt-speak sum tymz and wouldn't want to misunderstand something you were asking for help on? Wink
Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems
timber
PostPosted: Mon Oct 09, 2006 3:56 pm    Post subject: Reply with quote
Dave,
i think its time you contacted Garmin UK and sent your i3 back for a repair. Don't go into this, that and the other quite simply it worked and now it doesn't.
I'm slightly confused Confused as to what model of i3 you have did it come with a sd card or have you obtained a card (latest i3's have the maps on the internal memory original have them on the card)
mussey1
PostPosted: Mon Oct 09, 2006 5:02 pm    Post subject: Reply with quote
Normally if the card (original i3) is removed the unit should not work at all and a display screen should ask you reinsert the mapping data.
Definately sounds as if something funny is going on!
Mussey1.
Lester_Burnham
PostPosted: Mon Oct 09, 2006 9:45 pm    Post subject: Reply with quote
Mussey1.
You can bypass this, and just use the base-maps - search the forum for the key presses required, it was discussed when we were all sending our cards back to Garmin for the v8 upgrades.
dave1976
PostPosted: Fri Oct 13, 2006 6:10 am    Post subject: garmin i3 freezing Reply with quote
BIG TY FOR ALL WHO TRIED TO HELP Wink
i fixed the problem ............
the problem was with the memory card, when i put the poi's on to my garmin they stored on the memory card which i supozzz is normal but for some reason this made my garmin freeze totally ...i fixed this by the only way i new how to clearer the memory card and that was by putting it in to a d600 mobile fone and deleting every thing i put on it and just leaving all stored gramin memory.....
so now i have a working system again but with no speed cams in it ......
i dont no if i put them in wrong in the first place but i have 2 admit im to scared 2 try and put them back in for i dont want the same trouble again or worse.......... Crying or Very sad
mk_graham
PostPosted: Fri Oct 13, 2006 9:44 am    Post subject: Reply with quote
Dave,
Try loading them straight to the i3 rather than to the card.
Beerbellybill999
PostPosted: Fri Oct 13, 2006 2:46 pm    Post subject: Reply with quote
I had this same problem whe i first got my i3. I had to send it back to Garmin. they just put a new card in it but couldn't explain why it had happened.
I didn't have a card reader then to check the card but I suspected it was a corrupt PIO file that was the problem. I would have deleted the file if I had a reader and from what you say this now supports my theory.
At least we know if this happens again in the future it can be resolved.
If it helps, my file went corrupt when I cut and pasted Quite a few POI from different sources. Now i just stick to just speed cams and Mafts excellent database. I loaded straight to the card via the i3(as i said I didn't have a card reader then)
Mine is the i3 with the maps stored externally on the card
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
