Pocket GPS World :: View topic - HELP! please
HELP! please
keenster
PostPosted: Sun Oct 08, 2006 5:48 pm    Post subject: HELP! please Reply with quote
can anyone show me a list of the bare minimum that needs to be in the GB map folder on the tomtom classic only im wanting to make my speed cameras work and need to remove the 100s that are in there please
alix776
PostPosted: Sun Oct 08, 2006 6:13 pm    Post subject: Reply with quote
which camera files are you using and what size storage card do you have
device Lumia 950 xl
keenster
PostPosted: Sun Oct 08, 2006 6:36 pm    Post subject: Reply with quote
i have standard tomtom classic card 128 i think and i have some oldish camera locations
keenster
PostPosted: Sun Oct 08, 2006 6:42 pm    Post subject: Reply with quote
ov2 and bmp
alix776
PostPosted: Sun Oct 08, 2006 7:03 pm    Post subject: Reply with quote
ok which file set are you trying to load the speedzoned or the consolidated
if you just copy them over they should over write the old ones
dont delete anything out of the map folder as youll fine the map wont work
you can delete any of the pois youve put on but original one must be left there take a back before you do anything
device Lumia 950 xl
keenster
PostPosted: Sun Oct 08, 2006 7:14 pm    Post subject: Reply with quote
i have been trying to load the speed zoned,consolidated and the all folder
i did delete them all earlier but as you said no maps then! so i backed them up and put them back on
keenster
PostPosted: Sun Oct 08, 2006 8:24 pm    Post subject: Reply with quote
ill post this so people can see what i have in the folder
PostPosted: Sun Oct 08, 2006 10:09 pm    Post subject: Reply with quote
It would be easier if you had set Explorer View to show as List and not as Icons.;)
keenster
PostPosted: Sun Oct 08, 2006 11:51 pm    Post subject: Reply with quote
oops sorry chaps didnt think Sad ill change it if you like
keenster
PostPosted: Mon Oct 09, 2006 12:00 am    Post subject: Reply with quote
hope this is better
sgould
PostPosted: Mon Oct 09, 2006 12:07 am    Post subject: Reply with quote
You've copied all the files!! You have each camera in three times!!
Delete:
pocketgps_uk_gatso (this has all the speed zoned gatsos combined in one file)
pocketgps_uk_mobile (this has all the speed zoned mobiles combined in one file)
pocketgps_uk_specs (this has all the speed zoned specs combined in one file)
And this one has all the above three files combined in it!! So delete it as well:
pocketgps_uk_sc
Also delete the matching .bmp pic files of the same name if you like.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
PostPosted: Mon Oct 09, 2006 7:39 am    Post subject: Reply with quote
The name of the Map Folder appears to be wrong and none of the DAT Files appear to be present.
Map Folder should be called Great_Britain-Map.
Are you able to use the Classic normally? Do you have functioning Maps?
If yes, I suspect that you have somehow created a New Folder, and copied the Cameras there, instead of Copying them to the correct Map Folder.
keenster
PostPosted: Mon Oct 09, 2006 10:48 am    Post subject: Reply with quote
yep its a screenshot of a backup.
ive deleted most of the things out of there now but still have the cameras all showing the one gatso symbol even if its a mobile site???
im still not sure which of the 3 folders to put in there?
PostPosted: Mon Oct 09, 2006 6:40 pm    Post subject: Reply with quote
Here are the files that should be in your Great_Britain-Map folder
(This is the entire contents of mine minus any .ov2 or .bmp files from POIs I've added).
CLINE.DAT
CNAME.DAT
CNODE.DAT
FACES.DAT
MAPINFO.DAT
POI.DAT
TMCODES.DAT
TRAFFIC.DAT
GREAT_BRITAIN.MID
GREAT_BRITAIN.MMS
GREAT_BRITAIN.PNA
GREAT_BRITAIN-MAP.CFG
Certainly the cline/cname/cnode dat files are essential. They ARE the map.
So if your maps are working, the pictures you have shown us are NOT either your actual maps folder OR a good backup of it!! As Oldboy says, have you somehow made a copy of your maps folder and put the camera filles in there instead?
Also, if it is a backup, why is the folder name wrong?
Your backup needs to be the entire contents of the card, with all the folders and their contents intact.
Have you looked at the SD card using Windows Explorer, with it set to "show hidden files and folders" and DO NOT "hide extensions of known file types" (both of these are set in the "Tools" menu / "Folder Options..." / "View" tab).
There should be around 9 or more folders and about 11 files that are not in folders. Of those folders only one should have a name that mentions maps at all (assuming you haven't added any extra maps).
To make a proper backup you should have selected everything (Edit / Select all) and copy and pasted it to somewhere safe.
Finally, what 3 folders are you talking about in your last post?
22.064 (26 Jun 24)
