Pocket GPS World :: View topic - Google Map on Speed Camera Thread
missing_user
PostPosted: Fri Oct 06, 2006 10:58 am    Post subject: Google Map on Speed Camera Thread Reply with quote
Is this Google map working correctly?
On entering the location in fails to provide a 'cross hair' and the message 'searching' appears!
The general location appears but not the excact location.
This problem appeared some months ago.
missing_user
PostPosted: Fri Oct 06, 2006 11:05 am    Post subject: Reply with quote
Just found the previous thread:-
here
Perhaps lbendlin can fix it again?
Thanks.
Edited by Privateer to tidy up link
lbendlin
PostPosted: Fri Oct 06, 2006 3:02 pm    Post subject: Reply with quote
your way of entering coordinates looks a bit, uhm, unique. How about trying a standard format?
Lutz
TomTom/TeleAtlas NAVTEQ
missing_user
PostPosted: Fri Oct 06, 2006 3:08 pm    Post subject: Reply with quote
On the Google map on the database website you have as an example:-
51.523 N, 0.8123 W
That is what I'm trying, but no crosshairs!
How can I input a camera location without seeing the exact location!
There has been a problem with this before!
Privateer
PostPosted: Fri Oct 06, 2006 3:42 pm    Post subject: Reply with quote
When I search for a location, say "Oxford" and zoom in a little and move the map around a bit (technical stuff I know) - the cross hairs do appear albeit rather small.
When I type in a location, say "51.76299, -1.19661" (centre of the Green Road Roundabout in Headington, Oxford), I don't get the crosshairs until I move the map.
Thus I’m not getting the cross hairs to appear until the map is moved.
Robert.
Garmin Camper 770 LMT-D
missing_user
PostPosted: Fri Oct 06, 2006 3:56 pm    Post subject: Reply with quote
Therefore the cross hairs are not at the input location, but at the centre of where you have moved to!
I use garmin to record, and then enter the details into Google but I cannot see the location cross hairs!!
No wonder the cameras end up 90feet from a Google road!
Privateer
PostPosted: Fri Oct 06, 2006 4:31 pm    Post subject: Reply with quote
Hi strumble,
I must admit to a bit of quick learning here as I always submit updates from the files created by POI Capture.
Here’s how I think the Google map should be used:
1. Type in your location or coordinates in the "Find a location" field.
2. Hit the "find" button
3. If necessary adjust the level of zoom.
4. Move the map until the cross hairs are on the target location.
5. Repeat step 4 until you're happy with the location of the cross hairs
6. Hit the "Update Co-ordinates" button, this fills in the Latitude and Longitude fields of the "Single Camera Input" area.
7. If You're unhappy with the location of the crosshairs redo from step 3
8. If you're happy with the location of the cross hairs then fill in the rest of the fields in the "Single Camera Input" area.
9. Hit the "Send Entry" button to send the details to the database administrator.
Robert.
missing_user
PostPosted: Fri Oct 06, 2006 4:59 pm    Post subject: Reply with quote
I have been doing that but
When I input the exact location of a camera from my Garmin unit, as 51.523, -0.8123 [this is an example from the submission Google map] I should see the exact location marked by the cross hairs!! But the cross hairs do not appear [until you move the map]
I cannot use your point 4
without losing the original 51.523, -0.8123.
Once you move the map the appearing cross hairs become the centre of a 'new map' view, and not the input location!
This is where the inaccuracy lies!
This fault existed before and was corrected.
missing_user
PostPosted: Fri Oct 06, 2006 5:10 pm    Post subject: Reply with quote
If you type 51.523, -0.8123 into http://local.google.com/ you get an exact location mark which remains constant on all zoom levels and if you move the map sideways!!!
This is what should be happening on the submission page.
You can see that the example location is clearly off the road!
Privateer
PostPosted: Fri Oct 06, 2006 5:13 pm    Post subject: Reply with quote
Perhaps we need a "Refresh Map" button that forces the cross hairs to appear on the map at the correct coordinates.
Lutz, would this be possible?
Robert.
missing_user
PostPosted: Sat Oct 07, 2006 11:03 am    Post subject: Reply with quote
This morning, 10amGMT, the Google map operation is not working!
The 'FIND' facility is not working at all.
All the other Google maps are working [Google Earth etc] it is just the map on the submission page that is a problem!
Has the layout of this website been changed/modernized?
missing_user
PostPosted: Sat Oct 07, 2006 11:13 am    Post subject: Reply with quote
I cannot understand your comment.
I use Garmin units, are you saying that the readings are not standard from them??
I also use the supplied example formats from the submission page
You can search using co-ordinates like "51.523, -0.8123" or "51.523 N, 0.8123 W" or places like "weybourne road, farnham".
lbendlin
PostPosted: Sat Oct 07, 2006 2:24 pm    Post subject: Reply with quote
N52 01.756 W5 04.333 is not standard. that's what I was referring too.
Should be N52° 01.756' W5° 04.333'
Anyhow, the raison d'čtre for the crosshair is - a privateer describes - to help you adjust the position if you see that it is not in sync with the map. If you are dead certain that your Garmin is right then you can simply enter the coordinates into the submission form, and don't need the map at all.
The way we are doing geodecoding (getting a place name out of a coordinate) is, uhm, not exactly how Google envisioned it. We are not using the Google Maps API for that (because it sucks) - we use Google Local UK. But we're doing that in a pretty twisted way which can break as soon as Google Local changes their output format. Which they do frequently...
Lutz
missing_user
PostPosted: Sat Oct 07, 2006 3:14 pm    Post subject: Reply with quote
But it is acceptable to Garmin, Google local, Google earth and on a 'good day' to the Google map on the camera submission page!
This is not acceptable to Garmin and MapSource!
Anyway this does not work on the Google map on the camera submission page! The whole FIND procedure is not working
Are you saying that the problem exists and this is the cause?
All I want to know is there a known problem [besides me!!]
Can anyone else in the UK confirm that the Google map on the camera submission page is working or not, please?
lupos0_1
PostPosted: Sat Oct 07, 2006 4:24 pm    Post subject: Reply with quote
Tghe ggogle map was working for me. It was the find section on the map that was not working
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
