Pocket GPS World :: View topic - Using BT GPS and BT HEadset, is this possible?
acmp
PostPosted: Tue Oct 03, 2006 2:51 pm    Post subject: Using BT GPS and BT HEadset, is this possible? Reply with quote
hi,
I've just got an MDA Vario and use a bluetooth headset for the hnds free in the car.
I'd like to move my TTN from my old iPaq rx3715 to the Vario but I'll need a new GPS to do this, so i thought why not get a bluetooth unit.
But I don't want to spend my money until I know for sure that the Vario will talk to both devices at the same time.
Does anyone know if this is possible?
Thanks in advance
Well if I had one wish in this god forsaken world, kids
It'd be that your mistakes would be your own
PostPosted: Tue Oct 03, 2006 6:49 pm    Post subject: Reply with quote
It is possible to have different BT devices running at the same time.
Be aware that in order to hear the TomTom navigation sounds through the headset you either need a Audio Gateway profile (WM2003 with Widcomm BT stack) or a A2DP capable headset (WM5 Microsoft stack)
acmp
PostPosted: Tue Oct 03, 2006 8:04 pm    Post subject: Reply with quote
Wow that's technical!
I have a plantronics 320. I was really only thinking of having the phone through the headset and use the speaker for TT, but if there's a chance I can get nav warnings throughthe headset then I'm really interested.
Thanks for the input.
pendlemac
PostPosted: Wed Oct 04, 2006 1:42 am    Post subject: Reply with quote
I run a TT BT GPS with an XDA Exec. The TT messages come through the speakers and the phone comes through a BT headset. The only thing I've noticed is that the CPU demands of TT don't half affect playback of my ring sound! :D
PostPosted: Wed Oct 04, 2006 8:37 am    Post subject: Reply with quote
You can get all the sound through the Bluetooth headset on the Exec:
fire up your reg edit software
go to HKEY_LOCAL_MACHINE/ SOFTWARE/ OEM/ VoiceCommand
Change the Launchapenable from 1 to 0.
I was using this set-up for a while, the wife doesn't like the sat nav voice - it is also handy if driving at night when the kids are napping - Mike
acmp
PostPosted: Wed Oct 04, 2006 1:29 pm    Post subject: Reply with quote
Super tip, thanks mike
acmp
PostPosted: Wed Oct 04, 2006 2:18 pm    Post subject: Reply with quote
hmmm,
I don't appear to have a launchapenable key.
I added it )Dword dec 0) but no sound.
Maybe my BT stack needs an update. think I'll go looking for roms.
alix776
PostPosted: Wed Oct 04, 2006 3:13 pm    Post subject: Reply with quote
just edit the launch app value to 0 just done it and its worked fine for me
device Lumia 950 xl
acmp
PostPosted: Wed Oct 04, 2006 5:27 pm    Post subject: Reply with quote
The only value I have is Path.
That said I can live with the built in speaker, I'll just get some ear plugs for my wife
acmp
acmp
PostPosted: Mon Mar 12, 2007 12:02 pm    Post subject: Reply with quote
I got a new headset, still a Plantronics, and thought I'd give this another go.
But still no Launchapenable value. Again I've added a Dword of 0, soft reset but no joy.
My current setup is:
TTN6
BT GPS (1.2)
BT headset (2.0)
T-Mobile Vario
The gps works well, though I'd like to upgrade to a BT2.0 one. The new headset works very well but still no voice prompts from TTN via the headset.
If I am on a call then system noises do come through the headset, such as reminder beeps. But annoyingly no TT instructions.
Do I need a new BT stack or something?
Benmoffat
PostPosted: Tue Mar 20, 2007 4:06 pm    Post subject: Reply with quote
Hi All,
I posted a topic similar to this one regarding getting TT warnings through a BT headset a while back and did not get any answers so am hoping someone here can help.
I am using an SPV M3100 and a Jabra BT500V headset. I think that the headset is A2DP compatible from what I have read, but I am not sure if the 3100 has the widcomm stack. I do have a the Registry Key you talk about and I have tried changing this but it did not work.
Any help you could give me would be appreciated, as I use TT on a bike alot and having headset with wires poses its own risks.
Regards
Ben
alix776
PostPosted: Tue Mar 20, 2007 4:25 pm    Post subject: Reply with quote
one thing you could try is putting the widcom stack on the device but any bluetooth connections would need resetting up have a look in xda developers
device Lumia 950 xl
PostPosted: Tue Mar 20, 2007 5:53 pm    Post subject: Reply with quote
Ben, when you did the reg edit did you save the values you entered?
Once you have edited the key(s) save and exit the reg edit then press and hold the power button untill the device does a soft reset - this action updates the settings - Mike
Benmoffat
PostPosted: Wed Mar 21, 2007 12:54 pm    Post subject: Reply with quote
Thanks for the help. On doing some further research it appears that the headset (Jabra BT500v) is not A2DP enabled.
Do I assume then that I cannot use this headset for getting TT sounds with WM2005 for PPC (Orange SPV M3100).
Can anyone recommend a good A2DP headset at a reasonable price?
Ben
