Pocket GPS World :: View topic - Latest database
Latest database
JoeCurry
PostPosted: Fri Sep 29, 2006 3:52 pm    Post subject: Latest database Reply with quote
Unzipped ok but the folder containing ov.2 files is not readable.
I tried unzipping that but warned it was unreadable, I do I get to see the files in that folder in order to copy them to myTT1 card.?
PostPosted: Fri Sep 29, 2006 3:55 pm    Post subject: Reply with quote
Try downloading the database again for your device, its possible the file has become corupt - Mike
JoeCurry
PostPosted: Fri Sep 29, 2006 4:10 pm    Post subject: Reply with quote
No joy..here's a scren shot of the unzipped downloaded file.
Note the folder containing the ovs files does not have a readable extension
http://img241.imageshack.us/img241/8819/ov2wr6.jpg
PostPosted: Fri Sep 29, 2006 4:18 pm    Post subject: Reply with quote
From your image you have downloaded the single file version "pocketgps_uk_sc.ov2", so there IS NO folder. Everything looks correct.
If you downloaded one of the other options, you would get several .ov2 files
You also have the correct .bmp for that ov2, but it looks like you have not yet turned off "Hide extensions for known file types" in TOOLS / FOLDER OPTIONS / VIEW tab. Do that and you will have a better idea of what is going on (especially with Linux files where some have the same name before the extension (or no extension at all). While you are at it, select "Show hidden files and folders" in the same place too!
JoeCurry
PostPosted: Fri Sep 29, 2006 5:05 pm    Post subject: Reply with quote
Checked all that, yes it was the single file. I am trying to copy to the SD
card only from the PC using a card reader. How can I do that without accessing the folder containg the files?
I did it with the last upgrade but this one seems different.
PostPosted: Fri Sep 29, 2006 6:51 pm    Post subject: Reply with quote
Where the files are unzipped simply select all of the .ov2 and .bmp files so they are highlighted, right click and select "Copy"
Go to the SD card, open the GB map folder and in free space within Windows Explorer right click and select "Paste" from the pop-up, the files will then transfer across to the card, if the computer prompts to overwrite existing file simply click Yes - Mike
PostPosted: Fri Sep 29, 2006 7:05 pm    Post subject: Reply with quote
Don't worry about the file being unrecognised this is only because the PC doesn't know what to do with that data format, the TomTom software will recognise it and use it, give it a try and post back your findings - Mike
kevinx
PostPosted: Mon Oct 02, 2006 7:48 pm    Post subject: Speed Cam data base 300906? Reply with quote
2nd October, and no update to the database??
I note the last upadate was 150906, which is NORMALLY released at the end of the month.
Will there be a release shortly, or (going forward) will the Db be released mid month in future??
Maybe Darren's on holiday Laughing
cheers
Embarassed
HTC OneX (IceCreamSandwich), HTC DesireHD (Gingerbread) Co-Pilot Premium, GoogleMaps+CamerAlert352
TomTomOne (Original with the faster processor!)
v7.903, o/s 2344, GPSv1.21 Boot 5.0500
Mv710.1561(W Europe)+Traffic, N82 connection to GPRS traffic
Oldboy
PostPosted: Tue Oct 03, 2006 7:40 am    Post subject: Re: Speed Cam data base 300906? Reply with quote
There is no Normal .
See HERE.
TT Via 135 App 12.075: Europe Map v1135
kevinx
PostPosted: Tue Oct 03, 2006 8:15 am    Post subject: Reply with quote
Thanks Richard, but we have "become spoilt", in NORMALLY expecting at the end of month, as well as Mid month. Laughing
I see I'm not alone in my thoughts. how sad. Confused
PostPosted: Tue Oct 03, 2006 9:11 am    Post subject: Reply with quote
Normal depends on what I am doing at the time...
I am spreading my knowledge of database releases around at the moment as I will be away for nearly a month. I was schedulled to release a database today as part of the training, but due to personal problems the training has had to be cancelled. A new database will be released today however.
kevinx
PostPosted: Tue Oct 03, 2006 9:35 am    Post subject: Reply with quote
"A true Essex boy!" - "Spreading it around a bit", and "going away for a month"! :-)
Cheers Mike
Laughing
PostPosted: Tue Oct 03, 2006 11:53 am    Post subject: Reply with quote
Cant be. No fluffy dice or clapped out Ford Escort...
kevinx
PostPosted: Tue Oct 03, 2006 2:00 pm    Post subject: Reply with quote
And you didn't ADMIT to the Burberry that you wear as BasVagas!!
Laughing
22.105 (30 Oct 24)
