Simon0801 Occasional Visitor
Posted: Wed Sep 27, 2006 11:03 pm Post subject: It takes so long to find a satellite |
Is it just my GO 700 or does everyone experience some lngth of time from switching on to the TomTom locating a satellite? I frequently find this can be around 5 to 10 minutes. Typically I give up waiting and drive off knowing that at some point the TomTom will catch up and work out where I am.
Is there anything that I can do to improve this? Like adding an external aerial?
Simon |
trog100 Regular Visitor
Posted: Thu Sep 28, 2006 2:28 am Post subject: |
check out your local curries.. they have been selling the external aerials off for a tenner..
fifty quid is is the real price.. u might be lucky.. he he.. i bought one last week.. i dont need it but at a tenner i got one..
trog |
Oldboy Pocket GPS Moderator
Posted: Thu Sep 28, 2006 7:39 am Post subject: Re: It takes so long to find a satellite |
Simon0801 wrote: | Is there anything that I can do to improve this? | A lot depends on how often you use it.
If it has been several days since you last used it, or you turned it off the previous time a long way from your present position, then yes it can take somewhat longer.
If that happens to me, I leave it on a windowsill for a time, prior to going out to the car.
The external aerial can assist if you have a windscreen that is heat reflecting. If there is a marked difference in the Sat Display when you have it in the car, compared to on top of the car, then it suggests you might be better off with an external. Some users mount it on the rear parcel shelf, rather than on top of the car. _________________ Richard
Posted: Thu Sep 28, 2006 8:19 am Post subject: |
I use it once or twice a week, so I accept when I first turn it on there will be a delay. The most frustrating time is when I go somewhere for a business meeting. It gets me there, I turn it off for the meeting, and when I turn it back on a couple of hours later it takes 5-10mins to find the satellite. I don't have the patience to just sit there while it searches.
I was wondering if that is a problem with my TomTom or if that is normal. |
Tumbleweed Frequent Visitor
Posted: Thu Sep 28, 2006 10:03 am Post subject: |
Simon0801 wrote: | I use it once or twice a week, so I accept when I first turn it on there will be a delay. The most frustrating time is when I go somewhere for a business meeting. It gets me there, I turn it off for the meeting, and when I turn it back on a couple of hours later it takes 5-10mins to find the satellite. I don't have the patience to just sit there while it searches.
I have a 300 and find that satellite acquisition is generally pretty good (less than a couple of minutes, but sometimes, as you say, it will take 5-10 minutes, and this might well be after its been switched off for just a few minutes. Luckily for me this probably only happens once in every 20+ switch ons.
tw
Tw |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Thu Sep 28, 2006 10:16 am Post subject: |
Perhaps???
Change Preferences >>
Start-up Preferences >>
Check "Continue where I left off"
Works fine for me, but then I also have an external aerial |
Andy_P Pocket GPS Moderator
Posted: Thu Sep 28, 2006 12:58 pm Post subject: |
I'm becoming convinced that "time to lock" gets slowly longer since a reset.
Try a reset (stick pin in hole on bottom) then let it find a new lock. This WILL take ages, but after that (for me) it seems much better. No scientific proof or explanation for it, but it seems to work for me (and also might explain why updating software seems to improve things for many people)
As people have said above, other relevant things are:
1 ) How long since last switched off
2 ) How far away from where last switched off
3 ) Whether moving or still
The last one makes a BIG difference to mine (30secs - 1 min max if stationary, 2-3 mins if moving fast). |
Posted: Thu Sep 28, 2006 10:39 pm Post subject: |
Start up preferences is not an option on my 700. Well I can't find it listed anywhere.
Where does the external aeriel plug in? Any recommendations on variety? |
Antoeknee Lifetime Member
Posted: Thu Sep 28, 2006 10:46 pm Post subject: |
Assuming your on 6.xx look at page 6 of the preferences.
External antenna is wired into the mount. If you buy one you replace the part the TT sits on with the one in the antenna kit. |
Posted: Thu Sep 28, 2006 10:48 pm Post subject: |
Sorry that should have said 6.15 can't recall if it was on earlier version of 6.xx |
jean Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_et_003.jpg)
Posted: Thu Sep 28, 2006 10:53 pm Post subject: |
I find the weather affects how long it takes. Weirdly, if it is a clear bright sky then it takes longer. This week it took over 20 mins to find one - admittedly I was driving along at the time, but does not normally take that long. |
Posted: Thu Sep 28, 2006 11:11 pm Post subject: |
thick cloud or rain has a negative affect.. so will an upright type windscreen the metal roof stops it dead..
trog |
Posted: Fri Sep 29, 2006 8:53 pm Post subject: |
then on page 3 of 3 ...
Show ALL menu options.
Then start again ...
Change Preferences
then on page 6 of 7 ...
Check - Continue Where I Left Off
The only times I've suffered from long satellite acquisition times were when I had switched off, then driven away and switched on somewhere else. So I never do that now - even have it on when I'm going nowhere special and to the destination I do all the time (whitevanman I could get a call for a job at any time, so I need the satnav to be "aware"). And I ALWAYS set a route, so that I get the camera warnings/reminders. |
Posted: Sat Sep 30, 2006 12:04 am Post subject: |
My TomTom says App 5.410. Is that where you mean 6.xx? If so it doesn't appear as a menu item. |
PJLFC Occasional Visitor
![](http://img174.imageshack.us/img174/281/aggerli6zo8.gif)
Posted: Sat Sep 30, 2006 1:09 am Post subject: |
Did have this problem but have found since I bought an external aerial that I haven't had the problem since.
As an example I have recently got back from a trip to The Nurburgring in Germany,which included a mad hop through five countries in one day(very tiring but worth it!)
The only time I lost a signal was going through the tunnels on the link road in Antwerp,but it reacquired the signal virtually straight away.
Aerial was positioned at the front of the boot on an '05 Subaru Impreza.
Overall I was impressed with the external aerial and would consider it money well spent.
Hope this helps
Pete |
