Pocket GPS World :: View topic - Submit camera Map Icons
mickmarsh
PostPosted: Mon Sep 18, 2006 12:46 pm    Post subject: Submit camera Map Icons Reply with quote
where can i find an explanation for the icons used on this map especially the red and brown squares, that are on there that look like little windows.
Thank you
JockTamsonsBairn
PostPosted: Mon Sep 18, 2006 6:45 pm    Post subject: Re: Submit camera Map Icons Reply with quote
mickmarsh wrote:
Thank you
If you mean the map on this page, I think if you hover over the icon, I think there is a description shown in the status line. If you give a location, one of will have a look.
Jock
mickmarsh
PostPosted: Mon Sep 18, 2006 9:03 pm    Post subject: Submit camera Map Icons Reply with quote
Thanks for the info BGF, it is simple if you look properly.
Thanks again. :D
PostPosted: Fri Sep 22, 2006 6:51 pm    Post subject: Reply with quote
Following on from this...(only just had a chance to play with the map using Internet Explorer - none of these icons show up at all in a proper browser Wink )
Could someone 'in the know' explain a bit more, please?
What I'm seeing is:
1 ) there are coloured icons on the map for positions that are in the database;
2 ) there are red squares with crosshairs which are for entries that are...what? Already removed? About to be removed in the next version?
3) there are camera icons in monochrome. What do they signify?
I'm especially interested in these last ones, because one of the cameras that I successfully got moved, but which then went back to the original position in a later database version, is actually still shown in the correct position too, but "greyed out".
Anyone know?
JockTamsonsBairn
PostPosted: Sat Sep 23, 2006 3:41 am    Post subject: Reply with quote
What I'm seeing is:
Anyone know?
redlight
gatso
specs
temp
mobile
remove
That's all the ones I can guess at!
Jock
PostPosted: Sat Sep 23, 2006 1:02 pm    Post subject: Reply with quote
Thanks mate, I'd actually worked out those, because the type comes up at the bottom of the map when you click on them.
It's what "remove" actually means, and what the greyed out icons are for that I'm really after.
JockTamsonsBairn
PostPosted: Sat Sep 23, 2006 2:35 pm    Post subject: Reply with quote
Yeah, it's the icon that indicates what is/has to be done to that camera.
This information would help us enormously to see what was going on with cameras that we've submitted, and whether further clarification is required, so maybe someone in the know will come along and give us the info!
Jock
PostPosted: Sat Sep 23, 2006 10:56 pm    Post subject: Reply with quote
The greyed out icon is where a camera used to be and has been or will be deleted from the next database release.
The orange circles probably shouldnt be displayed, but are also deleted cameras that have the wrong flag set in the database. I am currently working my way through these in an attempt to clear them up.
Tulyar
PostPosted: Mon Sep 25, 2006 1:26 pm    Post subject: Reply with quote
Hi Mike,
Any chance of getting a key added to the map (or the area just above or below) to explain ALL the valid symbols clearly?
Cheers Steve.
22.064 (26 Jun 24)
