kevmullin Occasional Visitor
Posted: Sun Sep 24, 2006 9:01 pm Post subject: 710 help |
ive just bought a tom tom 710 and when i plug it into my computer it comes up devive not reconized, what am i doing wrong? |
Oldboy Pocket GPS Moderator
Posted: Sun Sep 24, 2006 9:13 pm Post subject: |
What Operating System have you got on the PC?
What Software Version have you got on the 710?
Have you install TomTom HOME?
Any information, and as much as possible of it, will help us to know what is going on, so that we help you.;) _________________ Richard
Posted: Sun Sep 24, 2006 9:25 pm Post subject: |
im on xp pro with no service packs, ive installed tom tom home direct from their website so its the latest one and the sat nav was bought new today so im not sure what vertion the software is |
Posted: Sun Sep 24, 2006 10:32 pm Post subject: |
Do you have a Card Reader? If so try the SD Card in that to see if it recognises it.
Also make sure the USB Plug is pushed in firmly at the 710 end, as some of the fittings are known to be tight. _________________ Richard
Pedro2NR Regular Visitor
Posted: Sun Sep 24, 2006 11:04 pm Post subject: |
When you turn on the unit, does the unit ask you to connect to your computer? if it doesnt, the unit is not properly connect to the home dock. |
Posted: Sun Sep 24, 2006 11:06 pm Post subject: |
it does ask on the unit and its a dock rather than a usb cable |
Posted: Sun Sep 24, 2006 11:11 pm Post subject: |
Reset the 710 - take it off the home dock turn it upside down and give the reset pin a prod with either a pin or paperclip, if you are unsure where the reset switch is please check the manual - IT IS NOT THE SMALL HOLE ON THE FRONT OF THE DEVICE, THIS IS THE INBUILT MICROPHONE.
Once reset and re-started, dock the unit and select connect to PC when prompted - Mike |
Martin4Jay Regular Visitor
![](modules/Forums/images/avatars/gallery/076.gif)
Joined: Aug 02, 2005 Posts: 150 Location: Monkton Heathfield, Somerset
Posted: Sun Sep 24, 2006 11:45 pm Post subject: Backup |
And remember to do a backup before you start deleting
Cheers |
Posted: Mon Sep 25, 2006 12:29 am Post subject: |
ive tried all the usual stuff like resetting it and installing and unistalling everything and it still comes up un reconized |
Posted: Mon Sep 25, 2006 7:13 am Post subject: |
Is it HOME or XP that says it doesn't recognise the Device? What is the Full Text in the Error Message? _________________ Richard
B0dger67 Occasional Visitor
Joined: Sep 14, 2006 Posts: 34 Location: Reading, Berkshire
Posted: Mon Sep 25, 2006 6:03 pm Post subject: |
Quote: | im on xp pro with no service packs |
Strange things happen with USB card readers (which is how the TT is seen by Windows) without at least SP1. You should have SP2 by now so get onto Windows Update and then see how you get on afterwards. If you've been caught out by the Windows Genuine Advantage Program and therefore can't update then you might be out of luck. |
Posted: Mon Sep 25, 2006 11:54 pm Post subject: |
sorted it, the home dock was a dodgy one so i got another one and now it works |
