geordie9 Occasional Visitor
Posted: Sun Sep 17, 2006 7:48 pm Post subject: TomTom One Sound Problem |
Wonder if anyone can help?
Trying to sort out a prob with my friends TT One. It plays no sounds (voices). It has the latest firmware ver 6.150.
Sounds play ok when used with TomTom Home software but nothing thru TomTom when disconnected from comp.
Checked to make sure sound is on and it is.
Any help will be much appreciated!
Thanks!
Daz |
Posted: Sun Sep 17, 2006 7:54 pm Post subject: |
update.....sound works ok when headphones are plugged in...suggests its the built in speaker!
has only one fixed this sort of problem before??? |
Posted: Sun Sep 17, 2006 8:11 pm Post subject: |
Not too sure if the following is available on this device (as I have not had a try of one yet) go to change Preferences/ Speaker Preferences and de-select the "Play music over external speaker" check box, at the same time de-select the "Play spoken instructions over external speaker"
If you cannot see these menu options please go to Change Preferences/ Show ALL menu options then press continue - and the above selections should be available - Mike |
Posted: Sun Sep 17, 2006 8:19 pm Post subject: |
that option is not there...i think it cos the tomtom one can not play mp3's like the 910 can. I have a 910 and that option is there.
Im pretty sure there is a prob with the internal speaker.
Just wondering if anyone has had a similar prob and how did they fix it. |
thebinman Banned
Posted: Sun Sep 17, 2006 9:05 pm Post subject: |
geordie9 wrote: | that option is not there...i think it cos the tomtom one can not play mp3's like the 910 can. I have a 910 and that option is there.
See if these good people can help; http://www.satnav-shop.com/ |
Posted: Mon Sep 18, 2006 9:30 pm Post subject: |
Took back off to check for any loose wires and unplugged and replugged the speaker connector but still no sound.
Now for some reason I am getting the TomTom start up sound which now lets me know that all is ok with speaker. Also noticed that the clock has reset to 12:00am. Maybe the faults are linked??
Still can only get sounds and voices thru the headphones.
Anyone got any ideas?
The firmware is ver 6.150.
Thanks! |
trog100 Regular Visitor
Posted: Mon Sep 18, 2006 9:53 pm Post subject: |
it cant be software else it wouldnt work thru the headphones..
it cant be the speaker else u wouldnt hear the startup sounds..
errrr.. yes.. that does kinda leave a mystery.. he he
trog |
eme Occasional Visitor
Posted: Thu Sep 21, 2006 9:25 pm Post subject: |
i have the same problem after updateing software, can not seem to get a answer anywhere. |
Tadger Occasional Visitor
Posted: Tue Oct 10, 2006 8:32 am Post subject: |
I've also got the same problem !!!
Has happened since I upgraded to 6.150 !! |
meriva Occasional Visitor
Joined: May 07, 2006 Posts: 5 Location: Birmingham England
Posted: Wed Oct 11, 2006 2:33 am Post subject: Sound Problem |
This happend to me tonight but after reseting a few times and taking the card out and putting it back in a few times it's now working ok. It was very strange and I hope it doesn't happen again. I realise this does not help much and is a bit vague but I was just trying anything. when the speaker was not working i could hear it through headphones. _________________ TomTom one with a 1 Gig Scandisk SD card |
wibbly Frequent Visitor
Posted: Wed Oct 11, 2006 8:38 am Post subject: |
I had a similar problem last night withe my TT1 Europe. No sound out at all. I toggled the mute icon. No help. Then, wierdly, it just started working again without even a reset.... |
thebinman Banned
Posted: Wed Nov 01, 2006 10:21 pm Post subject: |
Sorry to bring this one back up again but is there a definitive fix for this on a One V1?
TomTom drums sounds after removing/replacing SD card but no voices whatsoever.
Volume on 90%, select Tim, press Test....silence!
Select Jayne, press Test....silence!
Select volume, wind to 100%, press Test....silence!
Toggled between Turn on Sound/Turn off Sound....Silence!
Hard reset, updated firmware....silence!
Tried original & backup card....silence!
Is it just a matter of "keep on trying all the above" till it sorts itself out or is there a proper fix? |
thebinman Banned
Posted: Fri Nov 03, 2006 11:57 am Post subject: |
THANKS TomTom....NOT!
They reckon it's a speaker problem & suggest I return it for repair.
HOW can it be a speaker problem if the drums roll??
Anyone actually worked out a fix for this yet? Pretty please.... |
Posted: Fri Nov 03, 2006 12:49 pm Post subject: |
Has you got a backup of the original install? Maybe restore that? It's possible some file somewhere on the card tyat affects sound has got corrupt.
Also, if TomTom are offering a 'repair' you may instead get a new unit, and in any case you should get a unit back that actually works. |
thebinman Banned
Posted: Fri Nov 03, 2006 1:54 pm Post subject: |
wibbly wrote: | Has you got a backup of the original install? Maybe restore that? It's possible some file somewhere on the card tyat affects sound has got corrupt.
Cheers for the suggestion wibbly but back up card, different country map etc still nowt!
Hassle of sending it back irks me as I STILL cannot believe it's the speaker at fault.
Please keep 'em coming. |
