Pocket GPS World :: View topic - tom tom home problems
Goto page 1, 2, 3  Next
bj
PostPosted: Tue Sep 19, 2006 11:12 pm    Post subject: tom tom home problems Reply with quote
Can you please help I have dowloaded tom tom home to my pc when I plug in the usb cable the program starts ok if I click on Explore it finds my tom tom 700 and lists all the info ok. When I click on my go 700 bottom left it changes to my device a picture of a tom tom 700 comes on with the caption Please connect your tom tom device using a usb cable and turn on. As it working on the Explore tab and also does backups no problem it IS switched on. I have reloaded the software a number of times but can't get this option to work can you please help many thanks.
byron jones.
karma
PostPosted: Tue Sep 19, 2006 11:36 pm    Post subject: Reply with quote
Can I add my plea, too.
Exactly the same thing happens with me.
K
I said it was an upgrade. I didn't say it would be better.
Oldboy
PostPosted: Wed Sep 20, 2006 8:03 am    Post subject: Reply with quote
Did you get a 'Pointing Red Arrow' on the picture of the Virtual 700?
If so, turn the Virtual 700 on with the Mouse.
bj
PostPosted: Wed Sep 20, 2006 6:08 pm    Post subject: Reply with quote
Thanks for the reply there is no red arrow pointing to the on button.
many thanks.
bj.
bj
PostPosted: Wed Sep 20, 2006 6:57 pm    Post subject: Reply with quote
K
Karma
Have sent question to tom tom had no reply yet will post if reply is any use.
bj.
trog100
PostPosted: Wed Sep 20, 2006 7:06 pm    Post subject: Reply with quote
"As it working on the Explore tab and also does backups no problem it IS switched on."
do u mean its really switched on screen lit up or do u mean it just seems to work without being switched on..
odd cos if windows sees it so should home.. try connecting with the sd card removed.. let it connect then insert the card.. mine connects far more reliably this way.. my card readers dont like being plugged in with a card in them either..
trog
trog100
PostPosted: Wed Sep 20, 2006 7:08 pm    Post subject: Reply with quote
trog
trog100
PostPosted: Wed Sep 20, 2006 7:11 pm    Post subject: Reply with quote
the 700 has the hardrive dosnt it..i get muddled up with 710s which dont and 700s which do.. ignore my sd card comment..
trog
bj
PostPosted: Wed Sep 20, 2006 8:22 pm    Post subject: Reply with quote
[quote="trog100"]the 700 has the hardrive dosnt it..i get muddled up with 710s which dont and 700s which do.. ignore my sd card comment..
Thanks for the reply the tom tom is switched on and connected to the computer it just will not operate from the picture on the computer screen.
regards bj.
bj
PostPosted: Wed Sep 20, 2006 8:28 pm    Post subject: Reply with quote
[quote="bj"]
Thanks for the reply the tom tom is switched on and connected to the computer it just will not operate from the picture on the computer screen. Also when I said explore saw the info It was explore in Home not Windows Explorer which also sees it many thanks.
regards bj.
Antoeknee
PostPosted: Wed Sep 20, 2006 9:57 pm    Post subject: Reply with quote
Quite a lot of people are confused by this. Once you have connected and switched on the TT unit you need to activate the on screen device by click the on screen start button on the picture of your unit.
bj
PostPosted: Thu Sep 21, 2006 8:51 pm    Post subject: Reply with quote
Thanks for the reply please read a couple of posts ago the picture of the tom tom 700 is on the computer screen there is no red pointer by the on button on the tom tom the on button will not switch on the tom tom on the computer the explore button works and shows me all the programs on the tom tom. The computer can see the tom tom it shows all the info in it . It just will not operate it.
bj
PostPosted: Thu Sep 21, 2006 8:56 pm    Post subject: Reply with quote
Hi thanks for the reply no red arrow all other options work fine
regards bj.
Oldboy
PostPosted: Thu Sep 21, 2006 8:58 pm    Post subject: Reply with quote
I would try un-installing HOME by using Start | Programs | TomTom Home | Remove and then downloading HOME again. You will get the latest Version and, hopefully it will download the plug-in component that is needed for the Virtual TT.
Download from HERE.
bj
PostPosted: Thu Sep 21, 2006 9:50 pm    Post subject: Reply with quote
Download from HERE.
Thanks again I have just removed the program and reinstalled. It still has no red arrow I am begining to think there is a corrupt file left somewhere on the computer. Could you please advise me on the plug in component required many thanks
bjhere
Page 1 of 3
22.063 (19 Jun 24)
