Pocket GPS World :: View topic - has my garmin 13 had it?
edmond
PostPosted: Sat Aug 26, 2006 6:57 pm    Post subject: has my garmin 13 had it? Reply with quote
i bought a garmin i3 in Jan.
at the time i had a ford focus, i would plug the garmin in and within a matter of seconds i would have a signal.
about 4 months ago i bought a renualt scenic.
while transfering items from my old car to new i dropped the garmin.
now when i plug the garmin in it takes an age to get a signal,
today i drove of 40 mins before i got a signal.
i have the speed camera data base on the garim, it warns that the cameras are ahead when i am clearly only drving at 20 mph.
but the garmin things i am over the speed limit
could i have broken something inside when i dropped it or is the issue with the new car?
PostPosted: Sat Aug 26, 2006 7:12 pm    Post subject: Reply with quote
A couple of things spring to mind, firstly the new car probably has a windscreen that is coated with Athermic glass, this is known to attenuate GPS signals by a considerable margin.
There are a couple of options you can try,
Get a sat fix before you get in the vehicle, once the device knows where it is it should hang on to the signal, switch it on as you leave the house.
Obtain an external aerial, Maplins sell a compatable unit for very a very small outlay circa £15, put this infront of your rear view mirror and route the cable around the windscreen, connect it to the i3.
Never drive off without a GPS fix, the unit is working hard to find out where it is while stationary, if moving it will take ages (as you have found).
The POI Warnings at the wrong speed are probably down to the POI Loader application being set to use KPH rather than MPH when you last updated the camera database on the device, simply re-load the POI's but make sure you select MPH (its the second dialogue box entitled "What units should be used for distance and speed")
I don't think the unit is broken, just a tad limitted by the current vehicle and set-up, once this is worked through it should work OK - Mike
pjackson
PostPosted: Mon Sep 18, 2006 3:00 pm    Post subject: Reply with quote
mikealder, I have an i3 with the same problem as I have a Laguna. Could you post the link to the Maplins page to get the antenna please. Thanks.
zogman
PostPosted: Mon Sep 18, 2006 3:07 pm    Post subject: Reply with quote
not being funny mate ,but a google for maplins will save someone else doing the hard work for you....
PostPosted: Mon Sep 18, 2006 7:14 pm    Post subject: Reply with quote
Its easy when you have the page set as a Fav! - the code is A47FH read the data page to see its spec, size etc - Mike
pjackson
PostPosted: Tue Sep 19, 2006 10:02 am    Post subject: Reply with quote
Thanks for that. Only a tenner too! I'm off to buy one today!
PaulB2005
PostPosted: Tue Sep 19, 2006 1:54 pm    Post subject: Reply with quote
My Megane has the same problem.
Look above the rear view mirror. If the there is a section of glass that is covered in black dots then if you get the angle right you can there is no blue coating. I have my antenna stuck here and it works brilliantly. Just tuck the excess cable away.
Beerbellybill999
PostPosted: Tue Sep 19, 2006 2:19 pm    Post subject: Reply with quote
I have a scenic . The i3 will work without an extra Antena on the Driverside front Side fixed window(ahead of the drivers electric window), as the side windows don't have same glass.
I hope this helps
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
