Pocket GPS World :: View topic - Help flag : using Pocket Outlook contacts /tom tom 2 2.24.2
bidou
PostPosted: Fri Jan 09, 2004 10:01 am    Post subject: Help flag : using Pocket Outlook contacts /tom tom 2 2.24.2 Reply with quote
Can anyone help me to get rid of the following problem :
when using the navigation command from my contacts files,I get the following error message : " tom tom can not execute this command"
Pls note that when using the " showing the map" command ,everything works fine
Of course I asked the support of tomtom. But tomtom support has been quiet for too long ....
I even made a hard reset of my PPC. No change
8O 8O
apologize for not giving to you the right words of tom tom messages or instructions as my software is in French Wink
Config :
tomtom2 v 2.24.2 - French
GPS 2.08
HP 3950
SD 256 : Toshiba
Bidou
MrT
PostPosted: Fri Jan 09, 2004 10:19 am    Post subject: Navigate to Reply with quote
You are probably asking your TomTom to work out a to route somewhere in your contacts book. Where are you asking TomTom to calculate the route from? It will give this error if you only set a destination and not a departure point.
If you have your GPS on-line it should calculate your route from your current GPS position. If you go into TomTom and set wherever you want as your departure then go into contacts, it should navigate to where you want to go to.
It would be better if TomTom came up with the query as it would with a similar internal request similar to "Do you want to use your last known position as your depature point?"
22.063 (19 Jun 24)
