Pocket GPS World :: View topic - Won't turn off 710
Won't turn off 710
classy56
PostPosted: Sat Sep 16, 2006 11:13 pm    Post subject: Won't turn off 710 Reply with quote
I have a new 710 which works great apart from when I connect it via the home dock to Tomtom home, I can't switch it off when I disconnect it and have to do a reset !!
Does anyone have a solution to this problem, TIA.
brian3315
PostPosted: Sun Sep 17, 2006 1:43 pm    Post subject: Reply with quote
Did the same thing with my 510. The answer is to turn your TT off on its own off/on switch before disconnecting it from the cradle and shutting down TT Home.
PostPosted: Sun Sep 17, 2006 3:51 pm    Post subject: Reply with quote
Or Disconnect by Clicking My Device at the bottom of the HOME Screen
classy56
PostPosted: Sun Sep 17, 2006 7:14 pm    Post subject: Reply with quote
Thanks for the replies, tried both of those suggestions and it still won't turn off, it will turn off if I turn it off manually as suggested by Brian, but when I turn it on again I have to go through the language and other set up steps again Sad
PostPosted: Sun Sep 17, 2006 9:22 pm    Post subject: Reply with quote
It sounds like you need to run the Flash Utility from TomTom.
It has been mentioned before that there is a problem with some X10 devices.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=44990&highlight=flash
Read the Post by TuurG.
classy56
PostPosted: Sun Sep 24, 2006 10:53 am    Post subject: Reply with quote
Thanks Oldboy, run the flash utility and that seems to have done the trick, just need to get my phone working with the unit now, I can connect for hands free, but not for the plus services Crying or Very sad
22.064 (26 Jun 24)
