craigc38 Occasional Visitor
Posted: Sun Sep 17, 2006 9:53 am Post subject: Can i get POI warning sounds on Tomtom ONE? |
If so how?
i have downloaded and installed the customized POI warning sounds from here http://www.pocketgpsworld.com/tomtom-poi-alerts.php
i havent actually been ale to see if it works, is there a option to go into?
rgds |
Posted: Sun Sep 17, 2006 10:00 am Post subject: |
You need to go into Preferences/ Manage POI/ Warn When Near POI, select one of the Speed Camera POI's and configure for a warning, use the "Test" button to listen to each of the warnings and choose the one that matches the camera you are setting up, next repeat for each camera POI that you have loaded setting up a warning for each one, Once this is done go out for a drive and check its working, or use the Advanced Planning option to set a route past a camera then View Route/ Show Route Demo (set the speed to 100%) and watch the display for the warnings - Mike |
Posted: Sun Sep 17, 2006 10:08 am Post subject: |
Cheers dude, only had it 3 days.
im changin SD card today to a 256mb... can i put it on tomtom one, plug into pc and just copy all the software straight over to it? (i have all files saved on pc)
rgds |
trevor.dowle Lifetime Member
Posted: Sun Sep 17, 2006 10:28 am Post subject: |
craigc38 wrote: | Cheers dude, only had it 3 days.
rgds |
Why don't you just "restore" a backup on to the new card? If you haven't done one then now is the time to do so.
If you've only had the unit for 3 days, you may not yet have been onto the TomTom site and download the TomTom HOME software. I recommend that you do this as soon as you can, as apart from anything else, it makes 'backup' and 'restoring' a doddle. _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Sun Sep 17, 2006 10:40 am Post subject: |
ok i will do that, i have used all that software.. you would would be surprised to see how much i have done with it in 3 days.. |
