Pocket GPS World :: View topic - Voices?
Voices?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
RolandM
PostPosted: Mon Oct 09, 2006 9:19 am    Post subject: Reply with quote
Hi Ash10,
Great work you did!
Would it be possible to change your code so that it would work for other files than the English_British_.vpm as as well?
I have a Garmin Quest2 unit which does not use .vpm but .rgn files. However, I might be capable to change the file format from .rgn to .vpm by deleting the first 60 bytes of the file (please see
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=55116 ).
And maybe next be able to use your nice program.
Please let us know if you will update your program enabling the extraction of other files than theEnglish_British_.vpm
Regards, Roland
westyorkshireguy
PostPosted: Mon Dec 04, 2006 2:38 pm    Post subject: Reply with quote
I have one of the newer i3 units, where the map data is stored on the T/F Card.
Can I still change the voice prompts with this type of unit as when I place the card into the card reader there are only 2 files, and no folders on it????
Steve148
PostPosted: Sat Dec 09, 2006 9:24 pm    Post subject: Re: nüvi voices Reply with quote
1alfa wrote:
Helllooowwww Ash10 !!!
Will you give us some valuable input ???
I wonder if Ash has shrugged and gone back to other projects? Some of the posters in this thread sometimes gave the impression of being a little disrespectful towards his efforts.
That would be very unfortunate, as I'm sure there are thousands of non-tech i3 users who would be very grateful for his expertise. I'm certainly one of them - the camera manager utility is a godsend, for example.
Best wishes to all -
Steve
tomthompson
PostPosted: Sun Dec 10, 2006 4:28 pm    Post subject: Reply with quote
There is a new POIloader Beta version at the moment and it allows for the use of wav files for sounds Arrow
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
Abakus
PostPosted: Fri Jan 05, 2007 12:56 pm    Post subject: Split and merger tool Reply with quote
Hi guys,
i am worrying if the subject ist still hot.....
i have made a tool which should split and merge VPM file of any language with correct pointer tables.
any interest?
techker
PostPosted: Fri Jan 05, 2007 2:26 pm    Post subject: Reply with quote
so what wold you load the files with?did anybody try it on a garmin c330?
Abakus
PostPosted: Fri Jan 05, 2007 2:35 pm    Post subject: Merger Reply with quote
as far as i am sure, it works for C510 and c550, but i can successfully split and merge (for instance) sp2720 files of any language.
People have said the nuvi language files are the same as 510/550.
So it maybe worth a try if the 330 is matching as well.
Abakus
PostPosted: Fri Jan 05, 2007 2:37 pm    Post subject: Reply with quote
addition, the files are handled it the VPM Format and thus send ito the garmin unit into apropriate folder via USB connection
techker
PostPosted: Fri Jan 05, 2007 2:39 pm    Post subject: Reply with quote
but what application loads it?
Abakus
PostPosted: Fri Jan 05, 2007 2:41 pm    Post subject: Reply with quote
what application ?
my homemade tool? does the work, and explorere transfers it via USB ?
techker
PostPosted: Fri Jan 05, 2007 2:43 pm    Post subject: Reply with quote
wold it work for a 330?and can i get it?
Abakus
PostPosted: Fri Jan 05, 2007 2:44 pm    Post subject: Reply with quote
is it possible to upload programs onto this board?
techker
PostPosted: Fri Jan 05, 2007 2:49 pm    Post subject: Reply with quote
use pm.
octavs
PostPosted: Fri Feb 02, 2007 4:34 pm    Post subject: Reply with quote
Abakus, can I also have this wonderful program? 10x!
Ash10
PostPosted: Wed Feb 07, 2007 9:09 pm    Post subject: Reply with quote
See here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=52344
Page 9 of 10
23.092 (10 Sep 25)
