Pocket GPS World :: View topic - TomTom Go 510 question
p7hut
PostPosted: Fri Sep 15, 2006 6:07 pm    Post subject: TomTom Go 510 question Reply with quote
Hi all
TTG 510 arrived today, installed camera db no problem, all seems fine....went to put the nice 'warning sounds' on, instructions on forum say go to 'Change Preferences' and go to the 'About' section to find out what version I need.... except I can't find an 'About' section, the button isn't there!
Any help appreciated!
Paul
PostPosted: Fri Sep 15, 2006 6:16 pm    Post subject: Reply with quote
Paul before you start doing this please make sure you have a full back up of the SD Card in the TomTom device. You should store this on the PC and burn a copy to CD.
You can find what version your device is running by tapping the sat strength meter in the lower right corner of the main nav screen, next tap the version number on the right of the screen and the version info will be displayed - Mike
p7hut
PostPosted: Fri Sep 15, 2006 6:19 pm    Post subject: Reply with quote
Will try that now, had already made the back up, hehe :D
p7hut
PostPosted: Fri Sep 15, 2006 7:13 pm    Post subject: Reply with quote
Thanks Mike, worked fine.
A bigger problem seems to be that the device resets itself everytime I switch it on/off. It wants to go through all of the set up stuff each time, I'm thinking it must be faulty....?
PostPosted: Fri Sep 15, 2006 7:30 pm    Post subject: Reply with quote
Did it do this before you altered the data.chk file? - if so there is a problem, if this has only strated since you altered the file then its this file the unit isn't happy with, try swapping the old data.chk back on to the device and see if it still behaves the same way - Mike
p7hut
PostPosted: Fri Sep 15, 2006 7:47 pm    Post subject: Reply with quote
Found a thread in the TomTom section, advised to download flash exe. Did this, it doesn't lose the settings now (only tried it twice though) but.......
If I press the eject button on the home screen, the 510 freezes and I can't switch it off without reseting it, god damn thing!!!
22.064 (26 Jun 24)
