Pocket GPS World :: View topic - [b]sd card help[/b]
[b]sd card help[/b]
wayne21
PostPosted: Mon Sep 11, 2006 2:25 pm    Post subject: [b]sd card help[/b] Reply with quote
i just bought a sandisk ultra 2 card and need to know how to get the pois on the card so the navman can read it [/b]
Gee-Pee
PostPosted: Mon Sep 11, 2006 3:22 pm    Post subject: Re: [b]sd card help[/b] Reply with quote
Follow the instructions, here Exclamation
See here
for full instructions for installing Camera POIs on your
Navman iCN510 (V3 and newer)
iCN520 (SmartST 2005 or newer)
iCN530 (SmartST 2006 or newer)
iCN550 (SmartST 2005 or newer)
iCN620 (V3 and newer)
iCN630 (V3 and newer)
iCN635 (V3 and newer)
iCN650 (V3 and newer)
iCN7xx (SmartST 2006 or newer)
Pocket PC (V3 and newer)
PiN570
Follow the instructions precisely, and you should have no problems.
I suggest you download and print the instructions and keep with your device Manual
- if you have not got one, you can download one (in PDF) from the Navman website.
Gee-Pee
wayne21
PostPosted: Mon Sep 11, 2006 5:22 pm    Post subject: Reply with quote
thats not what i meant i tried to add mcdonalds poi and it said somthing like icn full so i bought a sd card to add more pois and on the icn they dont show up?
darrenwright
PostPosted: Mon Sep 11, 2006 5:38 pm    Post subject: Reply with quote
you can only activate around 25 POI's on the navman that you download
Gee-Pee
PostPosted: Mon Sep 11, 2006 5:45 pm    Post subject: Reply with quote
They are probably there OK - it's just that they will not show up. Set a route on which you know there is a McDonalds and see if the icon shows up. Wink
Gee-Pee
robertn
PostPosted: Mon Sep 11, 2006 10:49 pm    Post subject: Reply with quote
The POI's can't be loaded onto the SD card - you can move some maps there if your iCN is fll. failing that delete some languages as these use a large amount to memory - see previous posts on how to do all this.
TheM
PostPosted: Fri Sep 15, 2006 6:25 am    Post subject: Reply with quote
Note that “or newer” in the Camera POI list is incorrect for newer devices. If you have 530 or 7xx, they will only take speed cameras in three piece format (.bm, .map, .ini), older four piece format is not support (.bm, .map, .ini, .chk). Same goes for other 5xx that used four piece format – even though three piece format is newer it won’t work! The best way to ensure that speed cameras you download do work is to find them in CSV format (text file with comma separated values) and use your Navman Desktop that you got with the device to covert them into the format appropriate for your device.
For explanation how to load POI onto SD card check here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=45645&postdays=0&postorder=asc&start=15
Tim Buxton
PostPosted: Fri Sep 15, 2006 8:14 am    Post subject: Reply with quote
No, 'or newer' is currently still valid. The process for transferring the files hasn't changed, even though the number of files created by said transfer has. The only difference is that the 7xx defaults to search for .csv files although itcan still be forced to look for .asc files. It then uses them as normal.
Tim
22.094 (25 Sep 24)
