Pocket GPS World :: View topic - Red Square
Red Square
kirkie
PostPosted: Wed Sep 13, 2006 11:57 am    Post subject: Red Square Reply with quote
I have just downloaded the new camera database to my TT One and for some reason the cameras are showing as red squares.
Any ideas?
Oldboy
PostPosted: Wed Sep 13, 2006 1:36 pm    Post subject: Reply with quote
The indication of not having a bmp with the identical name to the ov2.;)
With Linux upper and lower case are not the same name, I believe.
PostPosted: Wed Sep 13, 2006 1:38 pm    Post subject: Reply with quote
That means that (for whatever reason) there is not a matching icon file for each camera file.
So for example, if you have:
pocketgps_uk_gatso_20.ov2
you also need:
Depending on which version of the database you are using, you will have upto 24 of each type of file.
So connect up to a PC and check the contents of your TomTom map folder to see if they are all there and are correctly named.
PostPosted: Wed Sep 13, 2006 1:39 pm    Post subject: Reply with quote
Yet again, Oldboy!!!! Confused
kirkie
PostPosted: Thu Sep 14, 2006 9:56 am    Post subject: Reply with quote
you also need:
Right thanks for that. I have downloaded it again, but it said it was there as it asked if I wanted to replace it so I said yes. I will let you know later if it has solved the problem.
22.064 (26 Jun 24)
