tmint Occasional Visitor
Posted: Sat Aug 19, 2006 2:04 am Post subject: TT 510 few problems |
Hi im new to the site, just after some info.
I got a 510 a few days ago and straght away the unit wouldnt read the sd card so got it chaned and now seems to be working ok. I can use my nokia N70 with the unit and microphone supplied but if i try to read or write texts on the unit it says not supported, is this correct ? Also i tried to put pictures on using tomtom home but again it says not supported? What do i need to do the use these functions, also can i use the instant messaging thing, how do i use it ?
thanks |
ColinS Lifetime Member
Joined: 30/03/2003 17:56:49 Posts: 120 Location: Dorset, UK
Posted: Sat Aug 26, 2006 2:08 am Post subject: |
Thanks mate, guess i shoulda checked that before i posted ! How does the buddies thing work ? is it one of the things you have to pay for ?
Can i copy the maps to a normal sd, one thats bigger so i can get more onto it ? i tried but it wouldnt read the standard sd card when it was done? |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Sat Aug 26, 2006 7:31 am Post subject: |
tmint wrote: | Can i copy the maps to a normal sd, one thats bigger |
Yes, but make sure it's a High Speed SD Card. Otherwise you're likely to have problems. _________________ Richard
Posted: Sat Aug 26, 2006 12:09 pm Post subject: |
Quote: | How does the buddies thing work ? is it one of the things you have to pay for ? |
I have not used it myself but from the TomTom website Quote: | TomTom Buddies is a free service. All you need to use the service , is a MyTomTom account |
You may like to take a look at http://www.tomtom.com/plus/service.php?ID=11&TT=bn5i27ksi56r3vvodrq5g9a656
Regards to the SD card, as you can see I use a Corsair 1GB 133x and Richard is quite right, slow cards spell trouble.
Colin _________________ Colin
Honda Jazz EX-Navi MKIII |
Posted: Tue Sep 12, 2006 6:03 pm Post subject: |
Thanks for your help. ive downloaded some voices for it, pasted them into the voices folder but for some reason they do not work. are all the voices available for the 500/700 etc or should they work and im doing something wrong ? ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
shauneco Regular Visitor
![](modules/Forums/images/avatars/1734307015456c655d9c0e3.jpg)
Joined: Feb 10, 2006 Posts: 135 Location: Mansfield,Nottinghamshire
Posted: Tue Sep 12, 2006 11:11 pm Post subject: |
Yes most of the old voice's work fine in the x10 range TomTom's, Although some dont. This is probably something to do with the audio format, Or the fact that some maybe encrypted to only work on a single device. This is to prevent illegal distribution of the voice's. I have most if not all of the voice's available for the TomTom range, 30 and only 25 of them work.
1, After putting the voice file's in the "voice folder" Try reseting the device.
2, Their should be 3 file's for each voice i,e dataXX (Bitmap Image), dataXX.chk, dataXX.vif.
Unless their TomTom original voice's which only have 2 file's dataXX.chk and dataXX.vif |
BodgerBaz Lifetime Member
Joined: Jun 12, 2005 Posts: 368 Location: Mörsdorf, Germany
Posted: Wed Sep 13, 2006 9:57 am Post subject: |
Hi there,
I'm moving over from running TTN5 on a PDA to TomTom GO510 (which is being delivered today)
I was interested in your comments about using fast SD cards.
1. Do you know how fast the SD card is which ships with the GO510?
2. Most recognised 'fast' SD cards are around the 10Mb/sec (66x) or 12Mb/s (80x) so is the quoted 21Mb/sec (133x) really necessary or is this a bit of overkill?
3. Would I really notice any difference between say 66x and 133x? I mean, will it really respond twice as fast or redraw twice as fast or is it all relative?
Thanks for your time
Bodger |
Posted: Wed Sep 13, 2006 1:20 pm Post subject: |
BodgerBaz wrote: | 3. Would I really notice any difference between say 66x and 133x? I mean, will it really respond twice as fast or redraw twice as fast or is it all relative? | Probably not, but it's the speed that it reads the Card that is needed. If the Card is the bottleneck, then it will be a slower re-draw.
Mines X66 and I have no problems. _________________ Richard
Posted: Wed Sep 13, 2006 1:31 pm Post subject: |
OK, thanks for that Richard. So as long as I use something around the 66x or better region I should be OK?
My GO510 has just arrived so I'm off to play.
Thanks for the reply.
Bodger |
