Pocket GPS World :: View topic - Transfer POI
Transfer POI
Cormorin
PostPosted: Mon Sep 11, 2006 6:14 pm    Post subject: Transfer POI Reply with quote
I have got the speed camera's from Gb Plus Major Roads of We on my classic tomtom but I have to change from the original map of Great-Britain-Map to the new map to make them work.
Is there any way of transfering the safety caera POI to the old Great-Britain-Map ?
PostPosted: Mon Sep 11, 2006 6:44 pm    Post subject: Reply with quote
Welcome to the forum, simply add the POI files to the other map folder and set-up the warnings as required, this way you can have the cameras installed in both maps.
In the root of the memory card will be two map folders, one named GB the other GB_Plus the POI's need to be in the folder that contains the active (i.e. selected) map - Mike
Cormorin
PostPosted: Mon Sep 11, 2006 7:40 pm    Post subject: Reply with quote
The old map folder is called Great-Britain-Map but when I put the POI (ov2, bmp, ver files) into this folder from the new map GB_Plus they do not appear on the map or under the POI list????
Any other ideas ?
Oldboy
PostPosted: Mon Sep 11, 2006 7:46 pm    Post subject: Reply with quote
How many POI Files have you got in the Map Folder?
TT Via 135 App 12.075: Europe Map v1135
Cormorin
PostPosted: Mon Sep 11, 2006 8:40 pm    Post subject: Reply with quote
19 ?
Oldboy
PostPosted: Tue Sep 12, 2006 7:49 am    Post subject: Reply with quote
That's not too many.
After you've Switched Maps, do a Reset and see if reads the info.
Did you set up the Warn When Near in both Map Foilders?
Cormorin
PostPosted: Wed Sep 13, 2006 9:57 pm    Post subject: Reply with quote
no whats that
Oldboy
PostPosted: Wed Sep 13, 2006 10:34 pm    Post subject: Reply with quote
Cormorin wrote:
no whats that
Go to Change Preferences | Manage POI | Warn When Near.
This is a Menu for setting up Warnings when you are approaching Selected POI.
Cormorin
PostPosted: Fri Sep 15, 2006 6:42 pm    Post subject: Reply with quote
yup go that but the POI's don't even display in the browse map menu
Oldboy
PostPosted: Fri Sep 15, 2006 7:49 pm    Post subject: Reply with quote
In Browse Map the Icons will only appear if they are Enabled.
In Browse Map Tap Options , make sure the Option Points of Interest is Ticked.
Then tap POI and Select which POI you wish to see on the Map.
Press Done twice.
22.094 (25 Sep 24)
