wayne21 Occasional Visitor
Posted: Mon Sep 11, 2006 2:25 pm Post subject: [b]sd card help[/b] |
i just bought a sandisk ultra 2 card and need to know how to get the pois on the card so the navman can read it [/b] |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Mon Sep 11, 2006 3:22 pm Post subject: Re: [b]sd card help[/b] |
wayne21 wrote: | i just bought a sandisk ultra 2 card and need to know how to get the pois on the card so the navman can read it [/b] |
Follow the instructions, here
See here
for full instructions for installing Camera POIs on your
Navman iCN510 (V3 and newer)
iCN520 (SmartST 2005 or newer)
iCN530 (SmartST 2006 or newer)
iCN550 (SmartST 2005 or newer)
iCN620 (V3 and newer)
iCN630 (V3 and newer)
iCN635 (V3 and newer)
iCN650 (V3 and newer)
iCN7xx (SmartST 2006 or newer)
Pocket PC (V3 and newer)
PiN570
Follow the instructions precisely, and you should have no problems.
I suggest you download and print the instructions and keep with your device Manual
- if you have not got one, you can download one (in PDF) from the Navman website. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Mon Sep 11, 2006 5:22 pm Post subject: |
thats not what i meant i tried to add mcdonalds poi and it said somthing like icn full so i bought a sd card to add more pois and on the icn they dont show up? |
darrenwright Occasional Visitor
Joined: Jul 16, 2006 Posts: 46 Location: Crosby,Liverpool
Posted: Mon Sep 11, 2006 5:38 pm Post subject: |
you can only activate around 25 POI's on the navman that you download |
Posted: Mon Sep 11, 2006 5:45 pm Post subject: |
wayne21 wrote: | thats not what i meant i tried to add mcdonalds poi and it said somthing like icn full so i bought a sd card to add more pois and on the icn they dont show up? |
They are probably there OK - it's just that they will not show up. Set a route on which you know there is a McDonalds and see if the icon shows up. _________________ Gee-Pee
robertn Frequent Visitor
Posted: Mon Sep 11, 2006 10:49 pm Post subject: |
The POI's can't be loaded onto the SD card - you can move some maps there if your iCN is fll. failing that delete some languages as these use a large amount to memory - see previous posts on how to do all this. |
TheM Frequent Visitor
Posted: Fri Sep 15, 2006 6:25 am Post subject: |
Note that “or newer” in the Camera POI list is incorrect for newer devices. If you have 530 or 7xx, they will only take speed cameras in three piece format (.bm, .map, .ini), older four piece format is not support (.bm, .map, .ini, .chk). Same goes for other 5xx that used four piece format – even though three piece format is newer it won’t work! The best way to ensure that speed cameras you download do work is to find them in CSV format (text file with comma separated values) and use your Navman Desktop that you got with the device to covert them into the format appropriate for your device.
For explanation how to load POI onto SD card check here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=45645&postdays=0&postorder=asc&start=15 |
Posted: Fri Sep 15, 2006 8:14 am Post subject: |
No, 'or newer' is currently still valid. The process for transferring the files hasn't changed, even though the number of files created by said transfer has. The only difference is that the 7xx defaults to search for .csv files although itcan still be forced to look for .asc files. It then uses them as normal. _________________ Tim |
