tango2pints Occasional Visitor
Posted: Sun Sep 10, 2006 11:43 am Post subject: navman 530 loading speed cameras please herp |
please can someone help i have now read through entirely all the threads and i have also read the instructions from top to toe over and over again every time i try to load the camera files on the 530 i get no storage card found now all my mapos are stored onthe 530 not an sd card now whjen i insert a sd card i can download the speed cameras onto it but the nbavman will not find it
i have been told there is a wy of creating a new folder on the navman in the myflash folder but i have no idea how to do this please can someone spare me a bit of time to help me with this many kind thankjs
gra |
Gee-Pee Lifetime Member
![](modules/Forums/images/avatars/2753245604985889cd11f6.jpg)
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Sep 10, 2006 1:43 pm Post subject: Re: navman 530 loading speed cameras please herp |
[quote="tango2pints"]please can someone help i have now read through entirely all the threads and i have also read the instructions from top to toe over and over again every time i try to load the camera files on the 530 i get no storage card found now all my mapos are stored onthe 530 not an sd card now whjen i insert a sd card i can download the speed cameras onto it but the nbavman will not find it
gra[/quote]
Have you checked to see if the POIs are loaded on your device and have been activated - see page 46 of your manual.
Are you saying that what you have loaded onto your device do not work How have you checked to see that they do not work ![Question](modules/Forums/images/smiles/icon_question.gif) _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Mon Sep 11, 2006 6:10 am Post subject: |
th espped cameras will just not load onto my device for some reason??? |
Stanley_Tweedle Regular Visitor
Posted: Mon Sep 11, 2006 9:18 am Post subject: |
Can you see it as a Mobile Device in My Computer?
Check if you have the folder:
\My Flash Disk\Navman\Lightning\Navman\MYPOI
If the MYPOI folder is not there then create it at this location as you would create any other folder in windows. |
TheM Frequent Visitor
Posted: Fri Sep 15, 2006 5:49 am Post subject: |
Are you saying that Navman’s Desktop app will not detect SD card? Check which version of MS ActiveSync you have installed. If it’s 4+ and you don’t have any other new WinCE/PocketPC device which require it, try removing it and installing 3.7. iCN 530 has WinCE 4.2 kernel and that one, for some weird reason only M$ knows, prefers older versions of ActiveSync.
If you add speed cameras manually to MYPOI directory, as Stanley_Tweedle mentioned, make sure that you have all three components -- .map, .bm and .ini. If parameters set in .ini are not correct, it will still not work (i.e. they may show on the map and in searches but you get no warnings). |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Fri Sep 15, 2006 8:05 am Post subject: |
Hmm. I use ActiveSync 4.1 and transfer to iCN530, iCN550, iCN635, iCN750 and don't have any problems whatever. _________________ Tim |
