Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Wed Sep 06, 2006 8:53 am Post subject: |
It sounds like you have a duplication of Files. Explore the Folder to see what you have and do a 'head count'.;) _________________ Richard
Tradman Lifetime Member
Posted: Thu Sep 07, 2006 12:09 am Post subject: |
Thank you Richard,I found a complete copy of Great Britian Navigator Map in a file called itn, also I have the backup file on the SD card, I have saved and removed both. I will try it and see what happens. |
Posted: Sun Sep 10, 2006 12:08 am Post subject: |
I still have the same problem, I am getting a red light warning with some of my speed camera warnings on motorways, can't find any duplicate files but I have red light cameras with speeds on them. My total count of red lights is 984 does this sound OK.
I am using "Rays" excellent voice warnings could this be connected ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Sun Sep 10, 2006 8:08 am Post subject: |
Tradman wrote: | My total count of red lights is 984 does this sound OK.
I am using "Rays" excellent voice warnings could this be connected ![Question](modules/Forums/images/smiles/icon_question.gif) | There are 983 Redlight locations in the latest Database.
A lot depends how you use the Warn When Near. If the Redlight Warnings are set with a high range warning, and the Option, to Warn Only When On Route, is Unticked then it is possible to get Warnings from nearby roads.
As to 'Ray's Warnings', you would have to double check that you have the right Spoken Warning for each Camnera File, by using the Test Icon. _________________ Richard
