Pocket GPS World :: View topic - ttn2/activesync
ttn2/activesync
jaygsi
PostPosted: Sat Dec 20, 2003 11:16 pm    Post subject: ttn2/activesync Reply with quote
after instaling ttn2 mp pda will not connect with activesync?
PostPosted: Sun Dec 21, 2003 10:34 am    Post subject: Reply with quote
Make sure you have properly exited TomTom Navigator before trying to sync it. Go into the Navigator screen, and tap anywhere, then go More (twice) then tap the EXIT button.
If you are unsure if it has exited and not running in background memory, perform a soft reset, then try connecting it to ActiveSync.
If the latter works, you may want to get yourself a good task manager. Pocket PC apps when you tap the normal X at the top right don't usually close, they just sit in background memory until another app needs the memory.
jaygsi
PostPosted: Sun Dec 21, 2003 1:35 pm    Post subject: Reply with quote
thanks dave
but i have a few more probs now.
when i first instaled tt the gps reciever did not work (rikaline 6012)so instaled gps dash to see if that will pick up any gps movements,no good so i deleted it and re instaled it over the top now the shortcut to tt dont work.
tryed reciever on nmea 0183v2 4800/9600/19200/38400 but no movement at all.
please help.as i dont know what to do.
what does a soft reset leave me with,just the basic programs?
if it needs a soft/hard reset can you tell what to do as my ipaq is second hand and i have no manual.
thanks again.
PostPosted: Sun Dec 21, 2003 3:20 pm    Post subject: Reply with quote
A soft reset is just like pressing the reset button on a PC or powering it off and on again. It might be an idea to do this and you can do so by pressing the stylus into the soft reset hole, sometimes it's on the base of the iPAQ and sometimes on the back (depending on which model you have).
Uninstalling GPS Dash shouldn't cause problems with TomTom, but you never know. If TomTom is working but you are just not receiving signal then it's possibly more down to the GPS Receiver.
Easiest way to diagnose would be to follow this article http://www.pocketgpsworld.com/winfastnavigatorppc.php
PostPosted: Sun Dec 21, 2003 3:30 pm    Post subject: Reply with quote
thanks again.
What model iPAQ do you have as the procedure for performing a hard reset difers between models?
jaygsi
PostPosted: Sun Dec 21, 2003 5:22 pm    Post subject: Reply with quote
i tried winfast navigator but nothing happend,tried different settings but still nothing the screen just stayed blank?
i am using ipaq3630
PostPosted: Sun Dec 21, 2003 6:44 pm    Post subject: Reply with quote
You should be connecting on COM1 and the baud rate really depends on what is required by the receiver. Normally this is 4800 but it may differ between GPS Receivers. If you still can't get a connection then it's probably the GPS at fault, in which case I would return it for a replacement.
Many have reported problems with the 6012 and had it replaced with a 6010 or another GPS and found this has worked. I'm not too sure what the difference is on the 6012 that may be causing problems, but we will see if we can get a 6012 in for review.
Abo
PostPosted: Tue Dec 30, 2003 1:24 am    Post subject: Reply with quote
You haven't got keyboard software or anything else that uses COM1 active have you?
jaygsi
PostPosted: Wed Jan 07, 2004 12:17 am    Post subject: Reply with quote
i have got gps 2.08 could this be causing my problems?with my gps reciever.
Abo
PostPosted: Wed Jan 07, 2004 8:38 am    Post subject: Reply with quote
Tom Tom have released 2.09 now. maybe you could try that?
jaygsi
PostPosted: Wed Jan 07, 2004 4:38 pm    Post subject: Reply with quote
is there any settings on my ipaq 3630 that are not set up corectly,ie in the settings/comections screen?that is stoping any conection with my reciever
johnnyxx
PostPosted: Wed Jan 07, 2004 4:40 pm    Post subject: Reply with quote
hi jaygsi where abouts are u in essex ?
jaygsi
PostPosted: Wed Jan 07, 2004 4:43 pm    Post subject: Reply with quote
grays,near lakeside m8
johnnyxx
PostPosted: Wed Jan 07, 2004 4:47 pm    Post subject: Reply with quote
its just that im in southend i was gonna say if u was nearer perhaps i could see if i could sort out your probs,
as all the probs u having sound like i had Laughing Out Loud
i had to do a hard reset load it all back in, download the gps driver for my pda
jaygsi
PostPosted: Wed Jan 07, 2004 4:50 pm    Post subject: Reply with quote
i have done 2 hard resets tryed 2 recievers still no good,may be its the com port on me ipaq.
22.124 (26 Dec 24)
