Pocket GPS World :: View topic - Best Method For POI warning on 910?
dpensox
PostPosted: Fri Sep 08, 2006 1:58 am    Post subject: Best Method For POI warning on 910? Reply with quote
I've just purchased a 910, and have subscrided to the speedcam database.
I've loaded evrything up, and I'm using the inbuilt POI warning feature?
I've noticed that it seems to pick up POI's within radius, is this the way it works ? I've read up on CheckPOInt, which allows the programming of an 'Approach Angle' so that the number of false alerts should be reduced, although CheckPOInt isn't available for the go's.
I've also seen POIWarner, which is available for the GO, has anybody had any experience of this program, or are there any others out there that people would recommend over the 910's inbuit warning
dirtyweeraincloud
PostPosted: Fri Sep 08, 2006 7:17 am    Post subject: Reply with quote
In the "warn when near POI" option, tick the box "Warn only if POI is on route" and the unit will not alert you of cameras within a radius.
PostPosted: Fri Sep 08, 2006 8:03 am    Post subject: Reply with quote
Please have a read through THIS it explains the speed camera download and installation with resepect to the Gp-910 - Mike
dpensox
PostPosted: Fri Sep 08, 2006 9:33 am    Post subject: Reply with quote
Hi all,
I had unchecked the "Warn only if POI is on route" deliberately. From reading through the forum I thought that the concensus was to leave this unchecked otherwise you aren't warned if the cameras weren't exactly on the road? The other obvious problem is that if you have no route set you won't get any warning.
peterc10
PostPosted: Fri Sep 08, 2006 10:37 am    Post subject: Reply with quote
The problem is that warnings are given by how near you are. The only way you can avoid that is to tick the warn when on route box. The problem with that as you rightly point out is that it will not warn you if you don't have a route set.
No way round this dilemma i am afraid. I untick the box and put up with the off route warnings. As soon as I get a warning I glance at the screen to see where it is.
Peter
HTC Sensation
Copilot for USA
Bury CC9060 bluetooth car kit & Brodit mount
dpensox
PostPosted: Fri Sep 08, 2006 10:57 am    Post subject: Reply with quote
OK,
Has anybody used any 3rd party POI waring applications ?
dirtyweeraincloud
PostPosted: Fri Sep 08, 2006 11:14 am    Post subject: Reply with quote
Same with 3rd party cameras.
It`s the unit.
22.094 (25 Sep 24)
