Rawhide Occasional Visitor
Posted: Wed Sep 06, 2006 1:30 pm Post subject: Garmin Nuvi 360 - not loud enough?! |
I've taken delivery of a Nuvi 360. It seems to work fine but I can't hear it!
I've put the volume up to the top but it's still not audible even driving at slowish speeds. Garmin say I need to hardwire it to the stereo
My i3 I could hear no problem at level 3.
I don't suppose I can improve this at all. Garmin suggested it was lowered to help with battery life  |
russo109 Occasional Visitor
Posted: Wed Sep 06, 2006 6:47 pm Post subject: |
Try using one of the different voices such as daniel which sounds clearer etc then the one which the unit comes preselected with :D |
Dilcymro Frequent Visitor
Posted: Wed Sep 06, 2006 6:54 pm Post subject: |
Hi Rawhide,
regarding your problem, I took delivery of mine a few weeks ago and on first using it found it to be very quiet. Obviously I turned the volume down and then up again, turned it on and off, still the same. then used it for a few days just in navigation mode on short journes and lo and behold the volume is now bang on, I even had to turn it down one day.
I think it needed a bit of time to settle in as they say, give it two or three days and just use it whilst driving around and run it off the power cable in the car , not on the batteries. I think you might find that it will "settle" down just like mine. If not you know where to come.
Regards....DIL _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
n4nick Regular Visitor
Posted: Wed Sep 06, 2006 7:28 pm Post subject: |
On good road surfaces I find the Nuvi okay when navigating but you do need to have it close to max. volume. On poor surfaces or when using the bluetooth phone connection it's poor and there is too much distortion at max. volume. Shame that you can use a bluetooth headset with the unit.
Nick |
partnervanman Occasional Visitor
Posted: Wed Sep 06, 2006 10:51 pm Post subject: |
Have you noticed where the speaker holes are? When you put the Nuvi into the cradles they get covered up. Bad design, i was contemplating biying some powered speakers.
Why should we have to do these things tho?
Why should we have these problems when we are paying £400/ why shoul we have to weigh up which sat nav has the least amount of problems. Its annoying! |
Scarecrow Lifetime Member
Posted: Thu Sep 07, 2006 12:47 am Post subject: |
I have to admit that on local journeys, I find the constant narration of instructions a distraction, and tend to use the unit for ETA and speed camera notification only, with the voice turned off.
However, for those who prefer to be told where to go all the time, or for just listening to MP3s, have you tried playing the sound through your car stereo? You can either use a cassette adapter or with one of those mini FM transmitters, both of which will plug into the earphone socket on the lower right hand side of your Nuvi? |
Yeoman Occasional Visitor
Joined: 08/04/2003 13:52:46 Posts: 26 Location: United Kingdom
Posted: Thu Sep 07, 2006 10:13 am Post subject: |
The problem with using the stereo is that I like to listen to the radio/cd's on my travels.
I have adopted a very basic solution. I attach a single earpiece to the unit which doesn't restrict me hearing and I can still hear the stereo and other sounds around me but hear instructions and warnings loud and clear. It also has the added benefit that any passengers do not have to listen to instructions.
It would be even better if I could use my bluetooth earpiece and better still if there was enough volume from the unit that all this was unnecessary. _________________ Compaq iPaq 3850; TTN5; 256k Sandisk CF; Transplant jacket; Arkon powered PDA speaker mount; External GPS antennae with MCX connector
SCRAPPED - now a Nuvi 310D with GTM12 - no external antennae required! |
Posted: Thu Sep 07, 2006 12:50 pm Post subject: |
Thanks to all. I've tried using 'Daniel' and it does sound a bit clearer. However that was off the cradle.
I had thought about wiring in the unit but I like a mimimalist dash which is one of the reasons I went for this unit.
I hope it does settle in but I'm not really sure thats how these things work Frustrating as I know Garmin could fix this with some sort of patch. |
MattCupra Occasional Visitor
Posted: Fri Sep 08, 2006 5:10 pm Post subject: |
I've got a Nuvi 300 and my unit is plenty loud enough I don't even need it turned up full.
You can test the speakers from the diagnostic menus (press & hold the time for about 5 seconds to access)
Re the cradle covering the speakers, the nuvi has 2 speakers, left & right so the cradle being in the middle should cover them. |
lexicon Occasional Visitor
Posted: Sat Sep 16, 2006 5:22 pm Post subject: |
MattCupra wrote: | I've got a Nuvi 300 and my unit is plenty loud enough I don't even need it turned up full.
The unit only has one speaker. Looking from the back, its on the left, partly obscured by the mount (or the GPS antenna if it's closed).
The rest of the "speaker grill" is a dummy.
When you do the left/right/both speaker test, it all comes out the same.
However the audio jack is stereo and that works for left/right/both tests.
Curiously, my manual says the audio jack is a power socket!!! |
