Pocket GPS World :: View topic - TT1 - loaded 6.15 and can't......
ranger_6
PostPosted: Wed Sep 06, 2006 6:25 pm    Post subject: TT1 - loaded 6.15 and can't...... Reply with quote
Find a way to 'clear route' without navigating to the current position. I tend to use the TT1 as speed camera locator and drive without a route specified. The old version had an easy button to clear the route.
Please help folks?
PostPosted: Wed Sep 06, 2006 6:30 pm    Post subject: Reply with quote
Go to change preferences/ and select "Show ALL menu options" now you will find the "Clear Route" icon has re-appeared in your Main Menu (page 3 unless you have been messing with the menu structure) - Mike
ranger_6
PostPosted: Wed Sep 06, 2006 6:33 pm    Post subject: Reply with quote
Many thanks. :D
Is there a way I can choose the options that are hidden?
PostPosted: Wed Sep 06, 2006 7:00 pm    Post subject: Reply with quote
You cannot select which icons are hidden or not within the application, but you can create your own menu that contains exactly the icons you want, and the order in which they appear on screen, the easiest way is to use note pad on the PC to text edit the tomtom.mnu file which is in the SDKRegestry folder, or search the net for the Skux menu builder site, where you can build the menu in a page by page graphical format, before loading the resultant file to the device. I am mobile at the moment, but will post a couple of links later if you can't find this information, In the mean time make sure you have a full back up of your memory card BEFORE messing around with any files - Mike
ranger_6
PostPosted: Wed Sep 06, 2006 7:55 pm    Post subject: Reply with quote
Many thanks Mike - I think that may be a little advanced for my limited technical skills Embarassed
