AdamBrunt Occasional Visitor
Posted: Tue Sep 05, 2006 11:30 pm Post subject: Linking maps together |
Hi all,
This is going to sound like a complete newbie question - and it probably is.
I have TTM5 and v6.32 of the GB Plus map. As I undestand it, this means that if I bought the French and Italian Plus maps, for example, and had all 3 on my memory card - then TTM would be able to get me from London to Milan in one continous journey.
Is this correct ?
If so, are the maps available from the Plus service on the TomTom website the Plus version of the maps ?
Adam Brunt |
Posted: Tue Sep 05, 2006 11:39 pm Post subject: |
Any of the PLUS maps contain the major roads of Europe, so assuming you can find the nearest main road from your departure point (quite easy as its normaly where you live or work) just the Italy Plus map is required to get you from your front door to destination in one hit.
OK so you don't get street level mapping through the UK but you don't / shouldn't need it, get to the port as fast as possible (Major roads / motorways will be on the Italy PLUS map), for the transit through France stick to the main roads and you will be OK with the same map Major roads will be on the Italy map.
When you get to Italy this is where you need the street level mapping, and it will be available without switching maps, simply use the extra level of detail - Mike |
a1gjv Occasional Visitor
![](modules/Forums/images/avatars/gallery/009.gif)
Posted: Wed Sep 06, 2006 1:15 am Post subject: |
Continuing on from the last poster I have a similar problem.
I use TomTom Mobile 5 on my Sonny Erricson p910i phone with the GB French and Spanish maps all on one 1 gig memory card. The problem comes for me when I go from Spain into France I have to stop and load the French map even though I have input my start and finish places.
Is there a way to change or intergrate this mapping so that I do not have to load other country maps when I cross borders it is a smooth transition from country to country. _________________ Regards
a1gjv
My Current weather is:
![](http://banners.wunderground.com/weathersticker/big2_both_cond/language/www/global/stations/08184.gif) |
Posted: Wed Sep 06, 2006 9:53 am Post subject: |
a1gjv wrote: | Continuing on from the last poster I have a similar problem.
Is there a way to change or intergrate this mapping so that I do not have to load other country maps when I cross borders it is a smooth transition from country to country. |
ah - I was assuming TT did this automatically ??
it kind of defeats of the object of having two maps on the same memory if TT can't seemless go between them. |
Posted: Wed Sep 06, 2006 2:01 pm Post subject: |
AdamBrunt wrote: | a1gjv wrote: | Continuing on from the last poster I have a similar problem.
According to my son who originaly have the phone he said you had to swap from 1 to the other, I must admit I have not crossed any goarder yet to try it out so perhaps I am jumping the gun a bit when I say it don't work.
Can anybody confirm one way or the other. _________________ Regards
a1gjv
adamf Lifetime Member
![](modules/Forums/images/avatars/2404478364437ecc2a2344.jpg)
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Thu Sep 07, 2006 12:47 am Post subject: |
i use western europe v606 taken from my old tt go 700 the whole of europe without changing cards?? you need a 2 gig card .....you can get these from tomtom its cheaper than buying a go 700 just for the maps ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Posted: Thu Sep 07, 2006 3:12 am Post subject: |
adamf wrote: | i use western europe v606 taken from my old tt go 700 the whole of europe without changing cards?? you need a 2 gig card .....you can get these from tomtom its cheaper than buying a go 700 just for the maps ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Thank you for your reply but unfortunatly it does not answer my question.
I have a 1 gig card with my TomTom mobile 5 with the following maps on France, Spain and Great Britian and I have just tried to plan a route from Girona Spain to Paris but because I did not have the french map loaded I could not do this.
The only way this journey could be planned was to do it in 2 stages Girons to the Spanish boarder with the Spanish map the change maps to the French one and then do the boarder to Paris.
Having to do this rather defeats to object of having a GPS navigation.
So is anybody can tell me how to overcome this problem I would be most greatful _________________ Regards
a1gjv
Posted: Thu Sep 07, 2006 8:07 am Post subject: |
If you only have the single country map loaded then you can only plan the trip as far as a border crossing, switch maps and continue.
What you need is a "Plus" map installed. the Plus version contains the applicable country mapped at street level PLUS the Major Roads of Western Europe, whith any Plus map you can navigate accross Europe. - Mike |
Posted: Thu Sep 07, 2006 10:38 am Post subject: |
mikealder wrote: | Any of the PLUS maps contain the major roads of Europe, so assuming you can find the nearest main road from your departure point (quite easy as its normaly where you live or work) just the Italy Plus map is required to get you from your front door to destination in one hit.
Ok, so if I have the GB plus map already then to get anywhere in Europe without reloading maps I just need the GB+ and all the relevant normal maps on the same memory card ??
Or would I need all my map files to be the Plus version ? |
Oldboy Pocket GPS Moderator
Posted: Thu Sep 07, 2006 11:15 am Post subject: |
You would need only the 1 Plus Map.
If your Destination is in Italy, you would be best off with the Italy_Plus Map. _________________ Richard
Posted: Thu Sep 07, 2006 12:36 pm Post subject: |
I am not sure if any on the replies here are directed at me regarding my problem of cross boarder navigation. Therefore I will ask another question, will the GB+ map go on a 1gig memory card on my TomTom mobile 5 on my phone or will I have to get a larger card, and if so where can I get this map from please, also does this map contain speed camera info as well. _________________ Regards
a1gjv
Posted: Thu Sep 07, 2006 1:13 pm Post subject: |
Oldboy wrote: | You would need only the 1 Plus Map.
If your Destination is in Italy, you would be best off with the Italy_Plus Map. |
If my destination is in Italy, what's the difference between having the GB+ & Italy maps compared to having the GB & Italy+ maps ?? Unless I am missing something, these would have the same coverage wouldn't they ?? |
Posted: Thu Sep 07, 2006 1:19 pm Post subject: |
a1gjv wrote: | I am not sure if any on the replies here are directed at me regarding my problem of cross boarder navigation. Therefore I will ask another question, will the GB+ map go on a 1gig memory card on my TomTom mobile 5 on my phone or will I have to get a larger card
I have TTM5 and GB+ map sitting quite happily on my 1GB memory card. It also had the normal GB map on it as well at one point.
By my reckoning (not sure how much bigger GB+ is compared to GB) according to http://www.tomtom.com/plus/services/mds.php you should be able to get TTM5, GB map, France map and Italy map on a 1GB card |
Posted: Thu Sep 07, 2006 1:49 pm Post subject: |
AdamBrunt wrote: | Oldboy wrote: | You would need only the 1 Plus Map.
To answer my own question ....
According to http://www.tomtom.com/support/category.php?ID=2&Language=1&FID=3393&TT=:
Quote: |
When you are travelling out of your region we advise you to use the cross-border navigation map of your destination country. This allows you to enter the exact address of your destination.
However, if you do not have the cross-border navigation map of your destination region, you can use the cross-border navigation map of the country where you start your journey. This allows you to use a highly detailed map at the beginning of your trip. Enter the address of your destination in the normal way. However, you may not be able to enter the exact address ...
Which implies that even with two maps on the SD (one of which is a + map) you can not plan a route from start to finish across countries. You can only do main road to finish or start to main road
And so, whilst I can can see you would want the + map of the destination country it is still a bit ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Thu Sep 07, 2006 2:32 pm Post subject: |
Also, are all the maps on TomTom's website Plus maps ? |
