Pocket GPS World :: View topic - Deleting voices on Mio C510/710?
IanCurtis
PostPosted: Sat Sep 02, 2006 10:14 am    Post subject: Deleting voices on Mio C510/710? Reply with quote
Can I delete all voices I do not need on my C510? I need only the Swedish voice and as the Mio sometimes chang itself to the American voice, it would be easier just to have the right one. If I want to put other voices back at a later time, would that be a problem?
CeeJay
PostPosted: Sat Sep 02, 2006 5:46 pm    Post subject: Reply with quote
Hi IanCurtis.
You can delete the voice files you do not require, but there may be a problem if it ever looks for the default (US male) voice when the Mio has one of it's moments. Not sure about this one as I have left all the voices on mine.
The voice changing back to US voice now and again is a known software bug.
However, there is a workaround.
Go to the Language page and change the language (not the voice) to any other language you understand. My guess is English would be good for you.
The Mio will then tell you Miomap will restart, click on Yes.
Then go back to the language page and change it back to Swedish.
The Mio will then tell you Miomap will restart again, click on Yes.
Now your selected voice will stay selected all the time, unless you ever have to do a hard reset, then you'll have to do all of the above again.
A soft reset does not affect it.
I've never had any reason to do a hard reset. A soft reset seems to sort out most things.
I use the workaround and it has never gone back to the US voice, so maybe you can try that first.
Hope this helps.
CeeJay.
IanCurtis
PostPosted: Mon Sep 04, 2006 9:25 pm    Post subject: Reply with quote
Thank you, CeeJay.
I was aware of the the bug and the workaround, but what I didnīt think of is that the bug would be back after a hard reset. So now I have applied the workaround again and it seems to work this far. Thank you.
Ian
22.094 (25 Sep 24)
Đ Terms & Privacy
