mancunian99 Occasional Visitor
Posted: Mon Sep 04, 2006 8:59 am Post subject: TT one cards |
Hi all , im a newbie to all this and was just after some advice
i have recently purchased my first ever TT and got the one as it was cheap and easy to use. The advice im after is the size opf the memory card as it seems very small and also which is the best card to go for (as in size upgrade)
thanks in advance
Jay |
Kremmen Pocket GPS Verifier
Posted: Mon Sep 04, 2006 9:23 am Post subject: |
Funilly enough I have just through the same exercise.
After the latest 6.15 software update I had to remove all voices except one to get enough room for the upgrade.
After reading the many articles on here for advice I have successfully migrated my data on the original to a new, larger SD card.
I purchased a Kingston 512MB 50x card from amazon.co.uk, along with a Sandisk 12 in one card reader.
I copied the entire contents of the TomTom card to a folder on my PC and duly copies the contents of the folder back to the new card.
I can confirm that all is well and all functions are identical to before.
I know that I could have used the TomTom as a card reader but I have seen some posts where a blank card can cause the TomTom to write a new config file that is different to the one required.
I wonder if I can defrag the new card for better response times ? Just a thought. _________________ Satnav:
Car Average MPG :
thebinman Banned
Posted: Mon Sep 04, 2006 9:27 am Post subject: |
TT Ones come with a 128Mb SD card with GB map.
Depending on what you want to add you'll need a 256Mb minimum for GB Plus major roads of Europe, 512Mb for most of the European maps, 1Gb for USA or 2Gb for full Western Europe.
If you're going to a 1Gb or more you should ensure you upgrade your firmware/application to v6.150 via TomTomHome. |
Posted: Mon Sep 04, 2006 10:50 am Post subject: |
thanks for the advice
i shall certainly be upgrading the card
once again thanks :D |
Oldboy Pocket GPS Moderator
Posted: Mon Sep 04, 2006 12:49 pm Post subject: |
Kremmen wrote: | I wonder if I can defrag the new card for better response times ? Just a thought. | I wouldn't Defrag any SD Card. It tends to thrash the life out of it.8O
It is much better to Copy the Card to the PC, then Re-Format the Card and finally Copy the Files back again. Each File will than be in one contiguous Block on the SD Card. _________________ Richard
Posted: Mon Sep 04, 2006 1:47 pm Post subject: |
OK - just wondered.
I have copied the PC contents to a blank card that was already formatted to FAT standard so hopefully the data is in one block as you stated.
I suppose I could let Diskeeper loose on an analyse process only and see what it comes up with. _________________ Satnav:
Car Average MPG :
JackOuzzi Occasional Visitor
Posted: Mon Sep 04, 2006 1:52 pm Post subject: |
I'm a VERY newbie as well ... with a spare 512mb card ... did the same copied etc etc BUT I am now being asked for an activation code for the map (which I have obtained) but I am unable to enter correctly as I have no provision for a 'space' on the TT keyboard - Any ideas? Or are these dedicated SD cards??
TIA |
Andy_P Pocket GPS Moderator
Posted: Mon Sep 04, 2006 2:48 pm Post subject: |
If I remember correctly, just enter the numbers without spaces... |
Posted: Tue Sep 05, 2006 9:43 am Post subject: |
Nope - does not work - tried evrything I can think of - I notice the 'new card' is 1Mb in file size than the 'old card'. Any omre ideas? It's a 512MB Toshiba Card |
Posted: Tue Sep 05, 2006 1:01 pm Post subject: |
Did you Format the SD Card before Copying TT Files back?
If not there could be some old, other, Files on there.
If you did Format it, did you use FAT16?
When you Copied the Original Files did you have the Option to Show Hidden Files ticked, in Windows Folder Options? _________________ Richard
Posted: Wed Sep 06, 2006 8:47 am Post subject: |
Yes - Card was Fat32 - ALL files removed - and fomatted as FAT (as opposed to FAT 32) so a completely clean formatted card.
Yes Hidden files are ticked and ALL files copied over. When this is done the new 512 card does work BUT .. I am asked for an activation code (which I have) but cannot activate as the TT keyboard has no space bar. I can 'activate' it using the virtual icon and my laptop keyboard, (virtual icon on my desktop freezes - subject of another post) and the activation is accepted .... close down virtual, close down device, changes are copied to card etc.
Next time I wind it up with that card it wants activating again .. *%$^£"$!^ 8O [/quote] |
Posted: Wed Sep 06, 2006 9:21 am Post subject: |
JackOuzzi wrote: | but cannot activate as the TT keyboard has no space bar. | It's going back quite a while, but I don't remember needing to put a space in. _________________ Richard
Posted: Wed Sep 06, 2006 9:50 am Post subject: |
Nope - wont accept it!! Needs spaces - works on virtual - accepts code - till next time I start it with that card in ....... fed up now puttin the 512 card back in me camera ... SOD IT!! :x |
kevinx Regular Visitor
Joined: Jul 31, 2005 Posts: 216 Location: Northern Earth!! ;-) (Essex)
Posted: Sat Sep 09, 2006 10:45 pm Post subject: |
mancunian99,
2Gb SD card about 20£ including shipping (5 days) from www.7dayshop.com (Channel Islands).
You'll have LOADS of space then _________________ HTC OneX (IceCreamSandwich), HTC DesireHD (Gingerbread) Co-Pilot Premium, GoogleMaps+CamerAlert352
TomTomOne (Original with the faster processor!)
v7.903, o/s 2344, GPSv1.21 Boot 5.0500
Mv710.1561(W Europe)+Traffic, N82 connection to GPRS traffic
colpac Occasional Visitor
Posted: Sun Sep 10, 2006 9:36 am Post subject: |
i formatted my new card (fuji 512mb) using fat32 then copied and pasted all the files over and it works perfectly, no activation codes needed. |
