Pocket GPS World :: View topic - NAVMAN ICN520 - Number of POI's....
fubardagger
PostPosted: Mon Sep 04, 2006 9:38 am    Post subject: NAVMAN ICN520 - Number of POI's.... Reply with quote
Hi, hope this is the right place to post my query. I can not find my instruction book, where I presume I would find the answer)
I have a ICN520, which works fine for my needs, I downloaded the 'latest' updates at the time for July. I found that I could name individual speeds and have icons and warning tones (20,30,etc., I downloaded individual files) safety POI's for the various cameras.
When I go through the menu only a certain number are 'ticked' activated, even if I un-tick some and then re-tick the ones I want, they do not become active. I have also de-selected several POI's for universities, shops etc.,
Is there only a certain amount of POI's that can be active, or am I doing something wrong ?
Marc
Tim Buxton
PostPosted: Mon Sep 04, 2006 9:44 am    Post subject: Reply with quote
Yes, the iCN range is limited to 25 Custom POIs although some people appear to have difficulty in activating more than 16. If your other POIs are important to you, I'd suggest using the 'Consolidated by type' cameras database which only uses half a dozen or so files instead of the 24 used by the speedzoned one.
It might also be necessary to delete everything and start loading them on again, putting the most important ones on first.
Tim
fubardagger
PostPosted: Mon Sep 04, 2006 9:49 am    Post subject: Reply with quote
Thank you Tim,
I have just counted up my POI's and I have 25 of which only 14 will activate, I will try what you have suggested and unload and then reload, otherwise I'll go for the consolidated file
Marc
22.064 (26 Jun 24)
