princeofpeace Lifetime Member
Posted: Fri Aug 18, 2006 2:34 pm Post subject: |
kirkie wrote: | Quote: | Switch on your TomTom. In the main menu, tap
'TomTom Traffic'. |
I don't even have this on my main menu...... |
Do you have POICapture installed |
kirkie Regular Visitor
Posted: Fri Aug 18, 2006 3:01 pm Post subject: |
princeofpeace wrote: | kirkie wrote: | Quote: | Switch on your TomTom. In the main menu, tap
'TomTom Traffic'. |
Yes on the 1st page... |
Posted: Fri Aug 18, 2006 3:07 pm Post subject: |
kirkie wrote: | princeofpeace wrote: | kirkie wrote: | Quote: | Switch on your TomTom. In the main menu, tap
'TomTom Traffic'. |
Well...i had the same problem and removed sdkregistry folder from TT which containd the POICapture menu files and alas the mobile and traffic icons reappeared - then able to get traffic promotion
I think I have seen a solution to this in the forums detailing how to reconfigure the files but can not find it - maybe some kind person will direct???? |
Posted: Fri Aug 18, 2006 3:10 pm Post subject: |
If I do that will the POICapture not work? |
Posted: Fri Aug 18, 2006 3:13 pm Post subject: |
kirkie wrote: | If I do that will the POICapture not work? |
No it won't work until you reinstall the SDKregistry file from original location i.e. to main director on TT - but...then...you lose the traffic icon etc. and you are back to original problem
I know there is a solution but cannot find it at the moment |
smiley1081 Occasional Visitor
Posted: Sun Sep 03, 2006 11:32 am Post subject: |
I have installed Home to start toying with it, and I had to uninstall it, as it conflicted with Mozilla Firefox and the all-important Biet-O-Zilla Firefox extension...
Now I am waiting to tell TomTom, but their on-line support service is off-line... |
Posted: Sun Sep 03, 2006 1:26 pm Post subject: |
princeofpeace wrote: | I know there is a solution but cannot find it at the moment | The solution is to open the TomTom.mnu file with Note pad on the PC (this file will be in the SDKRegistry folder), then move the lines of text around to get the order of the icons that you want (POICapture will be named as SDK1 in the menu file).
There are also online menu builders, but the edit using note pad is straight forwards.
Once complete save the file and check your work, you can have additional pages if you want - Mike |
Posted: Sun Sep 03, 2006 3:49 pm Post subject: |
Thanks for your reply - I have now worked it out - finally - novice novice novice
Cheers :D |
Posted: Wed Sep 06, 2006 3:01 pm Post subject: |
mikealder wrote: | princeofpeace wrote: | I know there is a solution but cannot find it at the moment | The solution is to open the TomTom.mnu file with Note pad on the PC (this file will be in the SDKRegistry folder), then move the lines of text around to get the order of the icons that you want (POICapture will be named as SDK1 in the menu file).
Thanks for that mate. |
Antoeknee Lifetime Member
Posted: Wed Sep 06, 2006 8:24 pm Post subject: |
My Traffic free trial (after 6.xx update) finally expired yesterday. So it looks like I got a month free again.
After successful use on a recent trip I've subscribed. |
