DracUK Regular Visitor
Posted: Mon Aug 28, 2006 12:30 pm Post subject: C510E Newbie questions |
Just bought this 510e and done most of the mods on here(thanks guys) but cant seem to find out how to do the following
1.Save a regular journey as a favourite
2.Save my Current gps position (wherever I am at the time)as a favourite
3.Save Itinary Routes
I think favourites are saved as pois but cant fathom it out.Too used to TomTom and Garmin me thinks
Any help appreciated
DracUK |
alix776 Pocket GPS Moderator
Posted: Mon Aug 28, 2006 1:02 pm Post subject: |
drack have a read throught IGo reveiw lutz touches on itineries there _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
CeeJay Frequent Visitor
Joined: Jan 06, 2006 Posts: 360 Location: East Sussex
Posted: Tue Aug 29, 2006 12:59 am Post subject: |
Hi DracUK.
1.
You've probably worked out by now that the Mio doesn't use favourites as we're used to, except for 2 locations, I use Home & Work.
You have to use the POI function. Different I know, but works all the same.
In Map mode, type in the address you wish to store as a POI (Favourite),
the Mio will then calculate the route and show you the destination on the map but it automatically switches back to cockpit mode. Switch back to Map mode and select 'Add POI' from the menu at the bottom.
You can also set up different categories within the POI groups eg. Friends, Family, Work, Useful etc.
2.
To save current GPS position as a 'favourite' is just an extension of the above.
What you have to do is switch to Map made, touch the arrow on the screen (your current GPS position), you will then get a radiating red circle appear on the screen. From the menu that pops up from the bottom select 'Add POI'.
You can then put it in a category that you have already created or create a new category.
This thing does take some getting used to but you will find that it does work well. :D
Hope this helps.
CeeJay. |
Posted: Tue Aug 29, 2006 8:48 am Post subject: |
Thanks Ceejay all sorted now.I was not realising you had to change to map mode
thanks again
DracUK |
Dilcymro Frequent Visitor
Posted: Tue Aug 29, 2006 3:21 pm Post subject: |
Hi all,
Ceejay, does this mean that if I go somwhere I dont know and I want to remember the location of my car: ie in a car park or if out in the wilds with my camera, then this is how I should do it and when I want to go back to the car just tap on that location.
Cheers...Dil[/quote] _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
Posted: Wed Aug 30, 2006 12:28 am Post subject: |
Hi Dil.
That would work.
Just remember, only in Map mode.
Took me a while to figure this unit out completely, but now all is good. :D
CeeJay |
Posted: Wed Aug 30, 2006 5:21 pm Post subject: |
Thanks ceejay :D
Regards...Dil _________________ ***************************************
Garmin Nuvi 2415
Posted: Thu Aug 31, 2006 12:21 am Post subject: |
Hi Dil.
Just had a thought.
Although your device will show you where your car is, it probably won't calculate a route back to it if you're 'off road'.
Bear in mind it is primarily an 'in car navigation system'.
I would suggest you try it out before you 'lose your bearings' on your next trip, just to be sure.
Let us know how you get on.
CeeJay. |
rronaldson Regular Visitor
Posted: Thu Aug 31, 2006 9:22 am Post subject: |
CeeJay wrote: | Bear in mind it is primarily an 'in car navigation system'. |
Well it is called the Digiwalker and Pedestrian is one of the options in Route Parameters so I would have thought that it would work anywhere that's mapped. _________________ Reg |
Posted: Thu Aug 31, 2006 2:35 pm Post subject: |
Hi rronaldson.
I hope your right but I have my doubts.
I have navigated to a couple of places where it has told me my destination is in an unreachable area.
If that's the case I can't see the software calculating a route in an unreachable area.
I hope I'm wrong, but it's not a feature I've tried out fully yet.
I was just trying to stop Dil losing his car. . :D
CeeJay |
Sallyann Lifetime Member
Posted: Thu Aug 31, 2006 3:27 pm Post subject: |
It doesn't need to calculate a route across a carpark. It only needs to show where the car is, and his current position. But the 'keep to road' option needs to be switched off.
Sal |
Posted: Thu Aug 31, 2006 5:33 pm Post subject: |
Hi all and thanks for the replies, it was due to the "pedestrian" mode that I asked as this was one of the features that caught my eye when I decided to buy one. If I go to a strange town and park in a car park I can hardly ever remember where the thing is even though I look for a large shop or something nearby to remind me, at the same time when out with my camera I can walk for miles, so it would be handy then aswell to be able to find my way back to the car, so obviously thought "pedestrian"
should do the job but wouldnt have thought about sallyann`s advice to turn off the " keep to road" option, so thanks for that sallyann.
I will be glad when they have sorted out the speedcams database though
as then this device will be top-notch. I dont feel confident enough to do the workaround some of you have done. _________________ ***************************************
Garmin Nuvi 2415
Posted: Sun Sep 03, 2006 1:21 am Post subject: |
Sallyann wrote: | It doesn't need to calculate a route across a carpark. It only needs to show where the car is, and his current position. But the 'keep to road' option needs to be switched off.
Sal |
Hi Sal.
I was assuming Dilcymro meant getting back to his car after rambling for miles in the countryside with his camera, not across a car park. :D
CeeJay. |
