mossy11 Occasional Visitor
Posted: Sat Sep 02, 2006 8:01 pm Post subject: Can't get the cameras to show up on Rider |
I've moved the files to Great Britain Map, but they don't show as POIs...Have tried speed zoned and single files, but no joy...Help! |
Oldboy Pocket GPS Moderator
Posted: Sat Sep 02, 2006 8:15 pm Post subject: |
When you Copied them to the ONE, did you copy them as Files?
Only the OV2 and matching BMP Files need to go into the Folder.
If you want to see them in Browse Map, you will need to Enable them/.
If you want to be Warned of them when driving, you will need to Select Warn Where Near in Manage POI.
You don't say which Software Version you are using. Perhaps you have exceeded the Limit of 39 in V5.xxx
If you have V6.xxx, which has a Limit of 100, the above points may apply. _________________ Richard
Posted: Sat Sep 02, 2006 8:22 pm Post subject: |
It's version 5.410 if this makes a difference, and I can't enable the POI's as they don't appear anywhere..although the files are definately in Great Britain Map....they are the only OV2 files there.....should there be more? |
Antoeknee Lifetime Member
Posted: Sat Sep 02, 2006 10:54 pm Post subject: |
Should be associated BMP as well. |
Posted: Sun Sep 03, 2006 12:09 am Post subject: |
As well as the Great Britain Maps folder there's one just called Great Britain....Putting the files in here seems to have fixed the snag...will now road test the unit and come back next time I get stuck!...Thanks |
