Pocket GPS World :: View topic - Navman ICN520
Navman ICN520
Maxmus
PostPosted: Fri Sep 01, 2006 9:27 am    Post subject: Navman ICN520 Reply with quote
I downloaded and installed speed camera files yesterday i followed the instructions exactly however it doesn't seem to be working they do nopt show in my poi's either can anyone help
Tim Buxton
PostPosted: Fri Sep 01, 2006 9:48 am    Post subject: Reply with quote
Did you get confirmation that each file had transferred to the device? Did you rename each file?
Tim
Maxmus
PostPosted: Fri Sep 01, 2006 9:52 am    Post subject: Reply with quote
Yes and Yes can see the files when "explore" with actisync many thanks for your interest
Maxmus
PostPosted: Fri Sep 01, 2006 10:11 am    Post subject: Reply with quote
Have just checked through 1 set wasn't re named it is still called POCKETGP could this be the problem all other 23 were renamed
Tim Buxton
PostPosted: Fri Sep 01, 2006 10:16 am    Post subject: Reply with quote
Not if only one file has that name. Using activesync, where exactly (full path) are the files located on your device?
Tim
Maxmus
PostPosted: Fri Sep 01, 2006 10:21 am    Post subject: Reply with quote
\Program Files\Navman\Shackleton\Navman\mypoi
Tim Buxton
PostPosted: Fri Sep 01, 2006 10:31 am    Post subject: Reply with quote
I never knew there was a Shackleton directory, but Navman do have some unexpected ones and the rest of the path looks correct. When you start up the iCN can you look under Preferences\My Data\My POI and tell me if the files show there and if the boxes are ticked? Also, under Preferences\Safety Alerts\Active POI select one of your POIs (assuming they're there) and see if it has ticks in all three boxes.
Just one other thing, when you transferred the files, did you set the visibility slider to Maximum?
Tim
Maxmus
PostPosted: Fri Sep 01, 2006 10:38 am    Post subject: Reply with quote
nothing showing in my poi's or safety alerts
Maxmus
PostPosted: Fri Sep 01, 2006 10:41 am    Post subject: Reply with quote
Also yes on vis slider
Tim Buxton
PostPosted: Fri Sep 01, 2006 10:46 am    Post subject: Reply with quote
Connect your iCN to your PC and start Navman Desktop and then start POIEditor. Click Device, Manage POI files. Does a list of your POIs appear there?
Tim
Maxmus
PostPosted: Fri Sep 01, 2006 11:50 am    Post subject: Reply with quote
yes they seem to all be there
Tim Buxton
PostPosted: Fri Sep 01, 2006 11:56 am    Post subject: Reply with quote
Then I'm afraid I've run out of options.
Tim
Maxmus
PostPosted: Fri Sep 01, 2006 12:08 pm    Post subject: Reply with quote
Thanks for all your help will have a crack at deleting all and starting from scratch
Maxmus
PostPosted: Fri Sep 01, 2006 12:12 pm    Post subject: Reply with quote
As a final blind attempt i copied all to "storage card my poi's" and seems to have worked !!!!! Thanks again for your help :P
22.064 (26 Jun 24)
