baradine Occasional Visitor
Posted: Fri Aug 18, 2006 9:24 am Post subject: Excellent article - inside 910 |
Thank you for your excellent article looking inside the 910. Have you prepared a similar article for any other TomTom devices? |
neil01 Frequent Visitor
![](modules/Forums/images/avatars/gallery/118.gif)
Posted: Fri Aug 18, 2006 12:09 pm Post subject: |
lbendlin wrote: | Of course that is just my personal opinion, but placing a wannabe 3D blue button next to a wannabe 3D purple button IS a catastrophe. There are many people with less than perfect color vision out there, and they do not appreciate this kind of indiscernibility. |
And possibly fall foul of EU disability legislation too!
But that aside, it is often so easy to avoid problems like this. Even something as simple as taking a black and white photograph, or screen print as appropriate) will highlight any colour problem areas. And, because carefully considered designs use contrast as well as colour to differentiate, it is usually clearer for all of us. |
fatmanscoop Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_005.gif)
Joined: Jul 07, 2005 Posts: 244 Location: Nottingham...
Posted: Fri Aug 25, 2006 9:07 pm Post subject: |
check out this video review of the 910. ..click the link and scroll down to 910 article
http://www.pocketinfo.tv/play/5803# _________________ Garmin xt mobile
Nokia N96
Liverpool F.C rocks |
Chris32 Occasional Visitor
Posted: Mon Aug 28, 2006 12:56 pm Post subject: |
I agree entirely about the poor quality of the mounting arrangements.
I wrote to TomTom within days of getting a 900 and they responded as though I simply had a faulty one, whereas it is clearly a poor design.
On another issue, I find that I have to reset the 900 fairly regularly. Yesterday for example it went completely haywire in the middle of a journey. No relation between the verbal instructions and the visible map and the car position indicator going through the middle of fields. Is this common, or have I got a bad one?
Chris Carroll |
lbendlin Pocket GPS Staff
Posted: Mon Aug 28, 2006 1:35 pm Post subject: |
I haven't seen hangups like these. Are you using any third party plugins?
Or is this happening at the same point over and over? Maybe a severe map issue. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Aug 28, 2006 5:15 pm Post subject: |
The only additions are the Safety camera data base files from this site.
I have driven many times through the area that I was in yesterday without difficulty. Once I had stopped and done a hard reset and re-entered the address I was looking for it worked fine. The problems did actually start earlier when it would not find a postcode (MK13 9JN) and I had to input the address in full. I have just tried again to input this postcode, but it will not have it. When I trawl through the postcode list for MK13, it jumps from 9HZ to 9WY, with nothing in between. If I enter the address directly it finds only MK13, so I guess there is part of the post code data base missing.
My reset difficulties are not normally as severe as this, usually it is a question of it being unwilling to switch on, or freezing when I am trying to load an address etc.
I had pretty much made up my mind to take it back shortly. |
Posted: Mon Aug 28, 2006 5:22 pm Post subject: |
That may be the best solution. _________________ Lutz
Oldboy Pocket GPS Moderator
Posted: Mon Aug 28, 2006 8:20 pm Post subject: |
Chris32 wrote: | when it would not find a postcode (MK13 9JN) and I had to input the address in full. | It's an out-of-date Postcode and isn't in the current Postcode Database. _________________ Richard
SpeedCam Frequent Visitor
Joined: Mar 18, 2004 Posts: 753 Location: Biggleswade, BEDS
Posted: Mon Oct 23, 2006 9:07 pm Post subject: |
Did you ever get to the internal harddisk, if so what size was it, and how was it mounted?
The reason for asking is to do with the device identification, as far as I can see all the x10 range are identical apart from the storage type. I therefore beleive that the device is identified based on it storage type, 510/710 if SD card found, 910 if harddisk. This info is displayed in the power on status screen. I don't think they have a different BIOS but I maybe wrong.
I'm not a fan of physical harddisk, therefore would it be possible to connect an SD card to an appropriate IDE converter and the 910 beleive it has a harddisk, but infact its using an SD card instead? Basically remove the harddisk and replace it with an SD card & IDE converter? |
Posted: Mon Oct 23, 2006 10:10 pm Post subject: |
The hard disk is behind the display, well packaged. It's a 20 GB disk.
You can replace it with a solid state disk. SD is a VERY bad choice, CF makes much more sense since it already has the ATA interface.
Don't worry too much about the device ID, it is stored in a completey different place, and not directly related to the hardware. _________________ Lutz
marcustandy Occasional Visitor
![](modules/Forums/images/avatars/4849054254615573191c69.gif)
Posted: Sun Nov 12, 2006 11:25 pm Post subject: |
I've had my 910 about 2 weeks now (they'd just been reduced by £100!!) and have had 'one or two' issues.
For the first two days of use, it froze about 4-5 times per day. A hard reset would 'free' the 910 and it would resume the route that it had been navigating prior to the freeze. This hasn't happened since the first few days despite the fact that it was being used all day (15hrs - truck driver), every day for the rest of the two week period.
I was planning to return it but as I had bought it from a town away from where I live, I never got around to it. The problem seemed to have gone so I didn't bother.
Some of the routes I was told to take were a bit questionable. Despite being set for fastest route (for a limited speed of 54mph) I was directed through urban housing estates when I knew for a fact it was not the quickest (or even shortest) route. Whilst crossing the Pennines (A646) I was twice told to 'turn left' when you could clearly see the road was about 30 metres long cul-de-sac which ended against the high vertical banking that makes up the base of the railway that runs above. It would've been a fool that followed that instruction!!
I find the MP3 player not the easiest to navigate - an option to just play all the files found would be nice instead of having to have them in 'playlists'. Looking through my (kids) pictures was a nice touch while I was waiting to load/unload.
My Nokia N80 can connect via Bluetooth but only for simple functions i.e. answering calls but not looking through my phonebook or text messages. The handsfree (built-in) mic is next to useless BUT using the external mic makes things just fine. I find it an easier and safer way of dealing with 'calls on the move' than any other hands-free system.
In summary, I like the 910. I waited for quite a while before forking out that much £$€'s and the £100 reduction tipped me over the edge. It's a cracking bit of kit but not the 'be-all-and-end-all'. _________________ marcustandy,
tomtom GO 910 owner. |
Posted: Sun Nov 12, 2006 11:38 pm Post subject: |
marcustandy wrote: | I find the MP3 player not the easiest to navigate - an option to just play all the files found would be nice instead of having to have them in 'playlists' | Simply go to the Music and photos icon, select TomTom Jukebox select Artist, at the top of the list should be "ALL" select this, on the next screen for selection of Album again select "ALL" at the top of the list, hit the first song in the list and the 910 will churn out the music one track at a time without requiring any intervention.
If you want true random selections to be played press the Options button (lower Left) and check the box for "Shuffle songs" - Mike |
Posted: Mon Nov 13, 2006 12:09 am Post subject: |
Thanks. _________________ marcustandy,
angryanderson Occasional Visitor
![](modules/Forums/images/avatars/gallery/abstract.jpg)
Joined: Mar 09, 2006 Posts: 11 Location: saint neots england
Posted: Tue Dec 19, 2006 8:15 pm Post subject: |
dear sir i have a tomtom go 910 and cable device for reporting traffic accidents (rds) is there any way i can tell if it is actualy working as i did just short of 200 miles on sunday from cambridgeshire to lincolnshier and back without any notice that there had beenno accidents or was it just a good day for all the motorists out on the road many thanks
dave anderson |
MickeyM Lifetime Member
Joined: May 12, 2005 Posts: 216 Location: Norfolk UK.
Posted: Sun Jan 14, 2007 12:24 pm Post subject: Tomtom 710v910 |
Lutz,
I already have the Tomtom Go,with maps of the UK and USA on SD cards. Do you think for me the best upgrade would be the 710, as you do not seem to be in favour of the hard disk in the 910.
Perhaps you would be kind enough to explain as to why? My Best Regards Mike Marsh. |
