wilfred Occasional Visitor
Posted: Mon Aug 28, 2006 10:28 am Post subject: NAVMAN 530 POI's |
Can anyone tell me how I save POI's to a SD card - I can save to the device in POI Editor but not to the SD card
Also I cannot delete POI's I have added to the device in the POI editor - am I doing something wrong? |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Mon Aug 28, 2006 10:50 am Post subject: |
You can't save Custom POIs to the memory card on the 530 but you might be able to transfer them there once they have been sent to the device. Just create the required filepath on the card and then move all the files into the new directory.
How are you attempting to delete POIs you've added? I can delete them using the POIEditor using
Device } Manage POI Files.
I delete what I don't want and then click 'Save'. _________________ Tim |
Posted: Mon Aug 28, 2006 10:59 am Post subject: |
Being a bit thick on this type of stuff, can you tell me how I would go about creating the file path on the card & then transferring the files.
Regarding deleting POI's, I have gone into the POI editor, clicked on the managing pOI files icon, highlighted the file, clicked on delete then ok and then yes. However when I then go back into managing poi files, the file is still there. |
Posted: Mon Aug 28, 2006 11:30 am Post subject: |
I'm not sure what the problem is regarding deleting POIs. It works for me as you have described, except that my files are actually deleted.
To create the directory on your SD card, use Activesync to explore your device. Double click on Storage Card, then Navman. You should see a list of directories, Arc at the top and Topo at the bottom, and three .ini files. Right click anywhere in the window and click New Folder from the dropdown menu. Call this new directory MYPOI.
Now navigate to the original MYPOI directory on the device (My Flash Disk, Navman, Lightning, Navman, MYPOI. Select all the files and cut and paste them into your newly created directory.
This might work on the 530; I've never tried it but it did work for me on my iPAQ in the past. _________________ Tim |
TerryWalsh Regular Visitor
Joined: Jul 29, 2005 Posts: 147 Location: Shrewsbury, UK
Posted: Mon Aug 28, 2006 1:08 pm Post subject: |
Hi Wilfred:
Could it be that your SD card is write protected? There will be small switch on the side of the card to do this.
Terry Walsh |
Posted: Mon Aug 28, 2006 4:15 pm Post subject: |
Terry
Thanks for that but I had already checked & it wasn't |
TheM Frequent Visitor
